Re: Pietenpol-List: Harbor Freight Multi-Function Power Tool opinions?
Posted: Thu Dec 03, 2009 7:45 am
Subject: Re: Pietenpol-List: Harbor Freight Multi-Function Power Tool opinions?I bought mine some time ago and aside from the noise and heat it generates the thing works really well. Overall I have used it for cutting and sanding and pleased with the results. The dremmel self adhesive sanding pads it, it may accept other dremmel attachments and cutters. Sooner or later youll have to make an after the fact cut or trim, this is the tool for that job.JohnIn a message dated 12/2/2009 11:31:42 P.M. Eastern Standard Time, kanderson051(at)gmail.com writes:I have one and works fine. I have been using it in a kitchen remodel.The blades seem to be of a cheap quality and wear easily. Dremel brand blades look like they might work but havn't tried yet. Look in some hot rod magazines Harbor Freight always has adds with this tool as low as 2999 and thereis always a 20% off coupon.KenOn Wed, Dec 2, 2009 at 4:32 PM, Billy McCaskill wrote:--> Pietenpol-List message posted by: "Billy McCaskill" I know some of you Piet builders out there have purchased the Harbor Freight MultiFunction Power Tool (currently on sale for $34.99), in your opinionis this a tool of sufficient quality that you would recommend buying one? I have purchased other hand-held electric power tools from Harbor Freight in the past, and have invariably been disappointed in them as they did not last very long even though they were used EXACTLY as intended and not abused in any way. I would like to have a multifunction tool like this, but ifthe quality is equal to those HF tools I have purchased before then I will pass on buying this. Thanks for your opinions.Billy McCaskillUrbana, IL/Baker, LAtail feathers almost doneRead this topic online here:_http://forums.matronics.com/viewtopic.php?p=275853#275853_ (http://forums.matronics.com/viewtopic.p ... 853#275853) ==========="_blank">www.aeroelectric.comooks.com" target="_blank">www.buildersbooks.comet="_blank">www.homebuilthelp.com="_blank">http://www.matronics.com/contributionle, List Admin.==========st" target="_blank">http://www.matronics.com/Navigator?Piet ... tric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?Pietenpol-List) ________________________________________________________________________________
