RE: Pietenpol-List: Re fitting nut plates
Posted: Tue Dec 22, 2009 11:17 am
Subject: RE: Pietenpol-List: Re fitting nut platesNot to be a Smart-Alec, but why don't you just put a dab of glue on the tabs of the nut plate?Seem like a lot of extra work, with basically the same net result. All the fiberglass plate gives you is a little more surface area for the glue.When attaching the nutplates for my empennage hinges, I used two tiny little brass screws (#0 x 1/4" long, I believe) to secure them, and also carefully applied epoxy. The epoxy is probably overkill, but I won't have any worries about the screws coming loose. I am NOT concerned about the penetration of the little wood screws. Then again, I also wouldn't be worried about the use of Tee nuts either. The advantage of nutplates is that the hole in the wood is only the size of the bolt, whereas with a Tee nut, the hole in the wood needs to be bigger, since the threaded portion of the nut is embedded in the wood.Bill C. [cid:890533215@22122009-245A]________________________________
Pietenpol-List: off topic
Posted: Thu Dec 24, 2009 3:07 am
For all Piets comunity My best wishes for all Piet builders and families on this Christmas. ________________________________________________________________________________
Pietenpol-List: Re: off topic
Posted: Thu Dec 24, 2009 6:43 pm
Beautiful work! Love the wood struts and the Jenny style gear. what type of wooddid you you use for the lift struts? What size wheels did you use, and wheredid you get the smooth tires? I'm not even close to the point of thinkingabout building my wheels yet, but I'd like to go with smooth tires just likethat on mine when I get there...Billy McCaskillUrbana, ILtailfeathers nearly doneRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: off topic
Pietenpol-List: Re: Re fitting nut plates
Posted: Thu Dec 24, 2009 6:46 pm
Wishing a Merry Christmas to all!Billy McCaskillUrbana, ILtailfeathers almost doneRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Re fitting nut plates
Posted: Thu Dec 24, 2009 6:57 pm
Original Posted By: B Church
Nicely done, Bill. I can't see any fault with your method. And as far as Tee-nutsare concerned, I've seen people flatten the prongs out and drill small holesin the flange for brads or small screws, and use them upside-down just likethe nutplates you show in your photo instead of counter-boring the hole in thewood and sinking the prongs into the wood. There's obviously more than onecorrect way to accomplish this job... Billy McCaskillUrbana, ILtailfeathers almost doneRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Fri Dec 25, 2009 6:54 pm
Pietenpol-List: Re: wood struts on 799B
Posted: Sat Dec 26, 2009 4:09 am
Original Posted By: Dan Yocum
douweblumberg(at)earthlin wrote:> ... newsletter has an article I wrote on tire shaving which tells how I did it.Very messy, but worth it I think.Where can we find that newsletter?BTW, beautiful struts!Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 26 Dec 2009 07:20:22 -0600
Posted: Sat Dec 26, 2009 9:21 am
Original Posted By: "Jack"
Thanks for the info on the struts and wheels Douwe. Good stuff!Billy McCaskillUrbana, ILtailfeathers almost doneRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
