Pietenpol-List: Happy New Year from The Cool Propeller Company
Re: Pietenpol-List: Corvair Piet Oil Cooler locations?
Original Posted By: shad bell
Shad, What temps are you getting on the ground and in flight? Gardiner Mason
Many, many thanks to Dan Helsper and P.F. Beck!!Starting next weekend is The Kitchen Remodel.guess that'll slow me down abit.Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(16 ribs down.)________________________________________________________________________________Date: Fri, 1 Jan 2010 14:56:41 -0800 (PST)
RE: Pietenpol-List: Happy New Year from The Cool Propeller Company
Gary,You did all that with a chainsaw? Wow!Mike _____
Yeah.you should see the grandfather clock I built with a chainsaw..;-0Gary _____
Pietenpol-List: Re: Happy New Year from The Cool Propeller Company
Original Posted By: airlion
That looks fantastic Gary!--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 2 Jan 2010 08:27:06 -0800 (PST)
> RE: Pietenpol-List: Corvair Piet Oil Cooler locations?
Gardiner,It is set for 4" back, now. I have a little room to move forward, ifnecessary, but I hope I don't have to. Those diagonal braces get theirfittings today. The upper fittings would need to be remade for any changes.Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(16 ribs down.) _____
Pietenpol-List: Re: Pietenpol Builder's Directory (Off Topic)
Thanks for fixing the site Glenn... I have been wanting to add myself for a while.Quite a list of Pieters there.Question... most of the list entries have a stock image (see below), but a few(Jack Phillips, P.F. Beck, Jack Textor), have added a photo. Is it still possibleto do that? If so, how?Thanks again!--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/vect ... ___Subject: Pietenpol-List: Re: Pietenpol Builder's Directory (Off Topic)
If you'd like a picture in your directory listing just email it to glennthomas@flyingwood.com. I think Matronics automatically changes the "at" symbol to make the email unusable. You can fix it yourself or use the email link at the bottom of the home page of http://www.flyingwood.com--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Gary,I made and installed my windscreens and cockpit covers before I did a weightand balance (duh). After the weight & balance I made to move the wing backand that necessitated new holes for the control cables and struts and I hadto relocate the windscreen. 4 inches sounds like a good start but a quickweight and balance check before the windscreens and fuse covers go on is agood idea.CheersPeterWonthaggi Australiahttp://www.cpc-world.com
Good advice! Thanks Peter.Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(16 ribs down.) _____
>>> >>Shad, What temps are you getting on the ground and in flight? Gardiner Mason>>________________________________
