Pietenpol-List: Motorcycle Link for Clevis
Posted: Wed Jan 06, 2010 12:32 pm
Original Posted By: H RULE
I've noticed that several people have used chain master links in place of clevises,which are obviously plenty strong for the task, but I can't figure out whatseries or type of chain these links are from. I run a 520 series chain onmy enduro motorcycle, which I believe is one of the largest of the motorcyclevarieties but the links that I've seen used in place of clevises are elongated,and most likely not used on a motorcycle drive. Anyone know whey type of chain these links are from, or where I can find some?--------Mark - working on wingsRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 6 Jan 2010 10:30:59 -0800 (PST)
Re: Pietenpol-List: Re: Using half of the tail cables? (long winded)
Posted: Wed Jan 06, 2010 12:42 pm
Subject: Re: Pietenpol-List: Re: Using half of the tail cables? (long winded)
RE: Pietenpol-List: Motorcycle Link for Clevis
Posted: Wed Jan 06, 2010 1:18 pm
Original Posted By:> K5YAC
Mark:The chain is a ANSI #50 roller chain for 3/16" clevis pins and bolts. Youcan get it here ==>
http://www.mcmaster.com/#ansi-single-st ... in/=59cxim or here===>
http://www.tractorsupply.com/. I wound up using left over chain fromwork and from friends. Just grind of the heads of the link pins and drivethem out, or use a chain breaker.Rick Schreiber> [Original Message]
Posted: Wed Jan 06, 2010 2:03 pm
Original Posted By: Dan Yocum
Thanks Rick... I'll check em out.--------Mark - working on wingsRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 06 Jan 2010 14:17:13 -0600
Pietenpol-List: Re: Motorcycle Link for Clevis
Posted: Wed Jan 06, 2010 2:49 pm
Original Posted By: "K5YAC"
That's right, Mark.Attached is a photo that Rick Schreiber posted to the List while back, to demonstrate.Bill C.Read this topic online here:
http://forums.matronics.com//files/rich ... ___Subject: Pietenpol-List: Re: Motorcycle Link for Clevis
Posted: Wed Jan 06, 2010 2:58 pm
Great! Thanks Bill and Rick. I know I have seen this in a couple of places, butas usual, when I want to see them, I can't find them. I think I am going to utilize this method.--------Mark - working on wingsRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Using half of the tail cables? (long winded)
Original Posted By: "wayne(at)taildraggersinc.com"
Well, since my name was mentioned, I guess I have to reply.Actually, I was not referring to the control cables at all, just the bracing cables- and since the attachment points of the rear bracing cables are not in linewith the pivot point (the rear edge of the stabilizer), the lengths of thosecables will also change SLIGHTLY if the front edge of the stab is shimmed upor down.However, since the pivot point of the stab incidence is basically the same as thepivot point of the elevators, there shouldn't be any need to readjust the controlcables.I'm done now.Bill C.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 06 Jan 2010 19:07:52 -0500
Re: Pietenpol-List: Motorcycle Link for Clevis
Posted: Wed Jan 06, 2010 7:35 pm
I used the links from a #520 chain--Jim lagowski----- Original Message -----
Posted: Wed Jan 06, 2010 8:50 pm
billspiet@sympatico.ca> >>> This is confusing.> You ask why you would need the cables to adjust the leading edge, and then> you say that you would just shim the horizontal stab at the leading edge and> re-adjust the cable tension to suit. That sounds to me like you're going to> need your cables to adjust the leading edge.> Every time the shimming is adjusted, all of your cable tensions will need> to be adjusted as well, since the cable attachment points are not the same> as the stab pivot point.> A simple and effective method used by many builders for fine tuning the> tail incidence , is achieved by simply adjusting the bracing cables, which> DOES put a slight twist into the horizontal stab - but it is minor (probably> visually imperceptible unless you're looking for it) - it is only for fine> tuning.>> So, the short answer to your original question:> "Sound, worthy idea or a waste?"> would be the latter, but I guess you've already come to that conclusion.>> There are alternate methods possible, but turnbuckles are likely the most> practical solution. If you use a swaged stud with a threaded fork, it will> look nice and clean, but you'll have a difficult time making adjustments, as> you'll have to disconnect the fork from the bracket, turn in or out the> adjustment, then pull the cable tight to re-With turnbuckles, the tension> adjustments are done with all of the cables in place.>>> Bill C.>>> Read this topic online here:>>
http://forums.matronics.com/viewtopic.p ... 363#28036= - The> Pietenpol-List Email Forum> -
http://www.matronics.com/Na=======================>>> >> *>> *>>________________________________________________________________________________Date: Wed, 6 Jan 2010 11:08:50 -0800 (PST)
> Subject: Pietenpol-List: Motorcycle Link for Clevis>>> I've noticed that several people have used chain master links in place ofclevises, which are obviously plenty strong for the task, but I can'tfigure out what series or type of chain these links are from. I run a 520series chain on my enduro motorcycle, which I believe is one of the largestof the motorcycle varieties but the links that I've seen used in place ofclevises are elongated, and most likely not used on a motorcycle drive. >> Anyone know whey type of chain these links are from, or where I can findsome?>> --------> Mark - working on wings>>> Read this topic online here:>>
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Motorcycle Link for Clevis
Original Posted By:> Bill Church > One of the other things that I think Bill was pointing out in his> post, which I didn't catch on the first read through, is that if you> are going to adjust the tail by shimming the front of the horizontal> stab you will then have to adjust the tension for all of your> empennage control cables. If you raise the front of the stab, the> upper elevator control horn attach points are now slightly farther> away from the bellcrank, and the lower attach points are slightly> closer. The rudder control cable would probably need a bit of> tweaking as well. Unless poor flying characteristics require you to> make gross adjustments by shimming the stab (and is there evidence> that a Piet built dimensionally to plans with the CG in the proper> range is going to need that?), it would be probably be easier and> quicker to adjust a couple cables via turnbuckles on the tail than> it would be to install different shims on the stab and have to> readjust the tension on 6 control cables....> > Ryan> > > On Wed, Jan 6, 2010 at 11:41 AM, Michael Perez> >> wrote:> > Bill, my response was based on the previous email reply, not a> direct question of why cables are needed for adjustment. I took> Shad's email as meaning, use the cables only to move the leading> edge. That may not have been his intent, so I asked. There was> no mention of shimming. No mention was made about fine tuning> either. I would not use the cables to adjust the leading edge of> anything. The shim is the adjustment, the cables are the> support. It sounded to me that, if the tail was not flying well,> that the cables would be adjusted to twist the thing. I am not a> fan of twist. I believe my email explained itself quite well.> Shim as needed, adjust cables to proper tension/correct alignment.> > "...insert the clevis pin (assuming - probably incorrectly -> that you're planning to use a traditional method of fastening> the fork, with clevis pins). "> > I thought I would make some balsa wood pins to slip into the> fork and hold it there with thread.> > As I stated, I have a handle on it now.> > > > > > --- On *Wed, 1/6/10, Bill Church / >/*> wrote:> >
> > >> > This is confusing.> You ask why you would need the cables to adjust the leading> edge, and then you say that you would just shim the> horizontal stab at the leading edge and re-adjust the cable> tension to suit. That sounds to me like you're going to need> your cables to adjust the leading edge.> Every time the shimming is adjusted, all of your cable> tensions will need to be adjusted as well, since the cable> attachment points are not the same as the stab pivot point.> A simple and effective method used by many builders for fine> tuning the tail incidence , is achieved by simply adjusting> the bracing cables, which DOES put a slight twist into the> horizontal stab - but it is minor (probably visually> imperceptible unless you're looking for it) - it is only for> fine tuning.> > So, the short answer to your original question:> "Sound, worthy idea or a waste?"> would be the latter, but I guess you've already come to that> conclusion.> > There are alternate methods possible, but turnbuckles are> likely the most practical solution. If you use a swaged stud> with a threaded fork, it will look nice and clean, but> you'll have a difficult time making adjustments, as you'll> have to disconnect the fork from the bracket, turn in or out> the adjustment, then pull the cable tight to re-With> turnbuckles, the tension adjustments are done with all of> the cables in place.> > > Bill C.> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 363#28036= > - The Pietenpol-List Email Forum> -
http://www.matronics.com/Na=======================> > > > > *> > " target="_blank">
http://www.matronics.com/Navigator?Pietenpol-List> tp://forums.matronics.com> _blank">
http://www.matronics.com/contribution> > *> > > *> > " rel=nofollow target=_blank>
http://www.matronics.com/Navigator?Pietenpol-List> et=_blank>
http://forums.matronics.com> llow target=_blank>
http://www.matronics.com/contribution> > *> > *> > > *-- Dan YocumFermilab
630.840.6509yocum@fnal.gov, http://fermigrid.fnal.gov"I fly because it releases my mind from the tyranny of petty things."________________________________________________________________________________Date: Wed, 6 Jan 2010 12:43:40 -0800 (PST)
