Pietenpol-List: glue: do not eat
Subject: Pietenpol-List: glue: do not eatI recall Jim Markle sending this photo out confirming thatwe're all just human and mistakes are easily made. Luckilythis mustard glue didn't ruin any sammiches that I know of.Just another reason the guy is endearing. Let's eat !________________________________________________________________________________Date: Mon, 25 Jan 2010 12:51:13 -0800 (PST)
Re: Pietenpol-List: firewall tip
Since Paul Harvey is no longer with us, I'll just let you know that in Jim's fridge,there is another, very similar container that says 'MUSTARD - DO NOT USETO BOND AIRPLANE PARTS WITH".And now, you know the "rest of the story". Good Day.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 25 Jan 2010 17:24:01 -0500Subject: Re: Pietenpol-List: firewall tip
RE: Pietenpol-List: Re: this group is really incredible
Group,I looked for Jim's "Pietenpol Builder's Guide to the Universe" onMykitplane.com but could not find it. Does anyone have a link??BrianSLC-UT-----Original Message-----
Pietenpol-List: Re: off topic question
It's in the "Files" sectionhttp://www.mykitplane.com/Planes/filesList2.cfm?AlbumID=40Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: off topic question
Douwe,You don't say what diameter helix you're talking about, but if you can find a localshop that has a tube roller, they should be able to roll it into the spiralyou want. Stretching a coil of rolled aircraft tubing is likely a lot moredifficult than you might expect - you'd be better off getting the tube rolledthe way you want it to be. You could also be limited by the length that you canbuy the tubing in (likely 20 ft max).Professional tube rolling shops use a machine similar (in concept) to that HarborFreight machine shown in the Youtube video, except that they are driven bymotors and hydraulic rams to adjust the radius. The more sophisticated machinesare programmable, and can change the diameter as the piece is rolled. The shopthat rolls the tube would need to have dies to match the diameter of tubingthat you are using.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 25 Jan 2010 18:48:49 -0500
Re: Pietenpol-List: off topic question
And check out this one with the extra roller for spiraling.http://www.youtube.com/watch?v=mYVEHUYE ... re=related> > You could do it yourself with a tubing roller. This is one example:> > http://www.youtube.com/watch?v=FO1FOxscqqM> > Jim Ash________________________________________________________________________________
Re: Pietenpol-List: motorcycle links
Original Posted By: "David Paule"
I don't have links on my control horns. I have turnbuckles with a fork endpinned directly to the horn. I do, however, have links joining the tail cablebrace wires. I used clevis pins instead of bolts. Since you're not pullingthe assembly up tight, as in bolting a prop to a hub, there's no need for anut. This makes the tail a teeny bit lighter as well.I threw in a couple of my just completed fuel system pics just for the heckof it.Clif> Guys, I know this should be simple, but...> Here are the questions:>> a) if you are using 3/16" pins across the through holes, are you using a > sleeve over the pin, to keep the two chain link sides from flopping about? > And if so, what is it, fuel line tubing or some such?>>> Tim in central TX________________________________________________________________________________
Nice tank work!But that valve control rod - that's not the way you're going to leave it, is it?David Paule ________________________________________________________________________________Date: Tue, 26 Jan 2010 13:28:10 -0500 (EST)
