Pietenpol-List: Another Airworthiness inspection scheduled
Posted: Thu Jan 28, 2010 2:49 pm
Ben; I had the same thing with my A65... it wouldn'tcome off the peg (oil temp) until I was in the airsometimes, and if I sat on the ground with it atidle, it would take forever. Maybe you can pre-warmthe engine before the inspector arrives? However,if you're just breaking in the engine after a major,it shouldn't be idled around very much. On myfreshly-majored A75, my mechanic advised againstputtering around and ground running until afterthe rings were seated and the cam followersand everything got lubed and seated in. I did havea few short ground tests to make sure there wereno leaks or other problems (good thing, too, sinceI had a leak at one of the oil gallery plugs andcould have pumped all the oil overboard if I'd beenin the air).Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net ________________________________________________________________________________
