Pietenpol-List: Re: how did you fall in love Jack ?
Posted: Tue Feb 16, 2010 9:41 am
Original Posted By: "K5YAC"
A long time ago I needed to ascertain the desired tension on something which was directly comparable to this. Turns out that optimum is no initial tension but zero slack, too. Some tension is better than some slack, so if you must, make the error that direction.The main purpose for initial tension is to overcome the effects of expansion or contraction. With metal airplanes that's usually due to temperature. With wood airplanes it might be a combination of temperature and humidity. I have no guidance for that, sorry.If it were my plane, I'd follow those rules of thumb that hurt - uh, that provide a moderate amount of initial tension, certainly not much. I have seen an old wood and wire fuselage that has damage due to excessive initial tension. Two main bulkheads have buckled.David Paule>> I think I caused more confusion than necessary with my "why use them at > all" comment. I was being a little sarcastic.>> I understand the purpose and the need for the cables. I'm not really too > hung up on the whole thing, I just haven't been able to find any definite > answer on how tight these things should be. Yes, I have read all the > replies here, and I do appreciate all the input. I've also read several > other threads that have basically ended in the same conclusion, which > is... there are several different techniques and a wide range of tensions > that will obviously work. I also spoke to several experienced > builders/technical advisors last night at our EAA meeting. None of them > seemed to think that what I had done was necessarily wrong, or dangerous. > The consensus was that I should have all the cables taut while maintaining > the squareness of the wing. How taut? Again, that was up for debate... > no one knew for sure.>> Given all of the input here, and from my discussions last night, I think > I'll back my turnbuckles off a bit. I agree that there is no reason to > apply excessive tension on the cables, this is just where I ended up using > the "twang" method. I fully agree that some amount of tension (it will be > my secret) is adequate for these cables to do their job and keep "drag" > and "anit-drag" from distorting my airfoil. Agreed?>> Thanks again for all the input. On to the next piece of the puzzle. :)>> --------> Mark - working on wings>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 636#286636>>> ________________________________________________________________________________Subject: Pietenpol-List: Re: how did you fall in love Jack ?
Pietenpol-List: how did you fall in love Jack ?
Posted: Tue Feb 16, 2010 11:45 am
Subject: Pietenpol-List: how did you fall in love Jack ?Congratulations on your Sportsman Pilot article Jack. Hoping my issue is waiting for me at hometonight.Funny how I've been friends with Jack for quite a while now thru the Pietenpol movement butonly after visiting with him recently did it ever occur to me to actually ask him what ever got himto building a Piet ?So Jack unless that question is answered in Jack Cox's article on you, could you tell us all how youfirst fell in love with the Pietenpol ?My story was pretty simple. Frank Pavliga gave me a ride in his Pietenpol and the view, the sensations,the whole experience made me sell my Champ so I'd have funds to start building a Pietenpol.So I gave up an enclosed cabin, 17 mph in cruise speed, cabin heat, and sexy wheel pants for a Pietenpol !(well worth it)Mike C.________________________________________________________________________________Date: Tue, 16 Feb 2010 08:03:48 -0600
Posted: Tue Feb 16, 2010 7:59 pm
I subscribed Sunday. I called the office today to make sure my subscription wouldstart with the current issue... the fellow told me that 3 or 4 people subscribedon Sunday and our first issue (the one with Jack's article) went in themail yesterday (Monday). I told him that I had not heard of the magazine untilit was mentioned on the Pietenpol forum... looking forward to checking it out.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
