RE: Pietenpol-List: Doesn't the GN-1 Grega have a beefed up rudder to
Posted: Thu Feb 25, 2010 10:06 am
Original Posted By: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]
You are correct Mike. Grega uses Pietenpols tail feather design, actually lookslike copies of Hoopman's 1934 drawings. Grega filled in the bottom rudder gussetwith spruce and also filled in between the lowest rudder rib capstrips fromthe LE to main beam with spruce and than bolts the rudder horn to this sprucefill-in.Skip----- Original Message -----
