Pietenpol-List: dimpletape
Posted: Mon Mar 01, 2010 2:39 am
First off, THANK YOU! Ryan for doing the scutwork of "Markle Mania" ensuringthat a great idea was turned into action.Shad, the dimpletape was easy to work with, just follow the directions. Hisprice is on the order form from his website. You have to order it the oldfashioned way and send him a ck. I made sure both the tape and the propwere warm since it's freezing here, stuck it on, rubbed it down with thebackside of a spoon and started her up. For a permanent installation, herecommends flowing some crazy glue around the edges, and you can spray athin coat of urathane over it if you please. I'm going to just use thecrazy glue. I'd varnish your prop first and if you want to varnish over thetape, install the tape before the final coat. I don't think you should fillthe holes in the tape with too much varnish. I spoke with the guy, and hesays you can do the same thing on a wood prop by using the tape as a patternand dimple the prop surface using a 1/8th inch ball grinder in a dremel anddoing halfway in. There's a picture of this on the site.Douwe________________________________________________________________________________
