Pietenpol-List: log your test maneuvers
Posted: Thu Mar 11, 2010 6:32 am
My FAA inspector told me something which may interest those of us startingor in the flight test phase.He said to be sure you log every test maneuver as you do it, like "70 degreebank", or "gross weight flown" etc because insurance companies have beenknown to deny coverage if the pilot cannot "prove" from the logbook thatwhatever maneuver they were in during the incident had been accomplishedbefore, within the test area. He said even after your test phase is done,you can go back into the test area, do the maneuvers, log them and you'regood to go.Seemed like valuable info.Douwe________________________________________________________________________________
Re: Pietenpol-List: Re: Phase 1 ballast up to gross?
Posted: Thu Mar 11, 2010 6:36 am
Good report Oscar. Now, how about a report on how your replacing the A 65 with the A 75 worked out?ThanksGene In rainy, windy Tennessee----- Original Message -----
Posted: Thu Mar 11, 2010 6:53 am
Original Posted By: H RULE
Re: Pietenpol-List: log your test maneuvers
Posted: Thu Mar 11, 2010 7:43 am
One thing I've learned dealing with FAA people, what your told depends on who your talking to.Bryan GreenElgin SC ----- Original Message -----
Posted: Thu Mar 11, 2010 7:51 am
Original Posted By: Craig Steffen
Gene; the engine swap is documented on mywebsite, here:
http://www.flysquirrel.net/piets/engine/A75.htmlThe engine runs strong and smooth, the swapwent quite well with very few hitches, andthis will be the first summer I get to flythe A75 in the heat to see how much differenceit will make in climb capability.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at
http://www.flysquirrel.net ________________________________________________________________________________Date: Thu, 11 Mar 2010 08:49:26 -0600Subject: Re: Pietenpol-List: log your test maneuvers
Posted: Thu Mar 11, 2010 8:15 am
rch 11, 2010 7:32:46 AM=0A> Pietenpol-List: log your test maneuvers
Posted: Thu Mar 11, 2010 9:13 am
Original Posted By: Jim Ash
Posted: Thu Mar 11, 2010 5:17 pm
Re: Pietenpol-List: A65 to A75 engine swap
Posted: Thu Mar 11, 2010 6:20 pm
Oscar, very informative and interesting. Beautiful engine and beautiful prop. Looking forward to reading what you have to say after you've flown it more and in the heat.Thank youGene----- Original Message -----
Posted: Thu Mar 11, 2010 6:29 pm
That's what you hope the other guy has when he taxis into ya.Gene----- Original Message -----
Posted: Thu Mar 11, 2010 7:39 pm
Posted: Fri Mar 12, 2010 11:00 am
Myron,If you purchased the full set of Pietenpol plans (including the three-piece wingplan), you will see both versions of the spar (1" thick, and 3/4" thick). Theoriginal design was 1" thick, with routed sections to reduce weight. This wasthe spar drawn in the FGM drawings as well as in the 1933/34 Improved Air Camperdrawings. Later, BHP switched to a 3/4" thick spar, with NO routed sections.The 3/4" spar is only shown in the drawing for the three-piece wing. The3/4" non-routed spar has approximately 90% the strength of the routed 1" spar(in simple bending). Both have been proven to be more than adequate in strength.Which one to use is strictly up to you.Your ribs can be built to accommodate the 1" spar, and then, later, if you decideto use 3/4" spars, just add 1/2" wide, 1/8" plywood spacer shims at each riblocation. Or, if you know for certain that you want to use the 3/4" spar, buildyour ribs to suit, and eliminate the little bit of extra weight and work ofthe shims.Bill C.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 12 Mar 2010 12:20:29 -0500Subject: Re: Pietenpol-List: log your test maneuvers
Re: Pietenpol-List: Re: New builder already needs help
Posted: Fri Mar 12, 2010 11:31 am
Subject: Re: Pietenpol-List: Re: New builder already needs help
Pietenpol-List: Re: 1/2" web idea. Spar options--one man's method
Posted: Fri Mar 12, 2010 2:48 pm
Subject: Pietenpol-List: 1/2" web idea. Spar options--one man's methodMyron, Group----here is how I did my spar and how I would do it again proposed in the attached sketch. I did a cost analysis of both methods and it was pretty much a wash as I recall with the proposed methodbeing way less work by not having to route out U-channels in those upper and lower 'caps'.Mike C.________________________________________________________________________________Subject: Pietenpol-List: Re: 1/2" web idea. Spar options--one man's method
Posted: Fri Mar 12, 2010 3:14 pm
Original Posted By: Dan Yocum
Mikee-Wouldn't a dado blade on a table saw make much quicker work of the channels inthe spar caps than a router would, to accept the spar webs?--------Oscar ZunigaSan Antonio, TXAir Camper NX41CCRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 12 Mar 2010 15:36:14 -0600
