Pietenpol-List: Front fuse question
Posted: Sun Mar 14, 2010 1:04 pm
It will be somewhat difficult to make such a change due to the connections required.Suggestions abound. Here are mine:a) Ask people what they like and don't like about their own panels, and give yours the benefit of the lessons they learned.b) Fly a few rental planes and see what you like.Personally, and I don't have a Pietenpol so this might not suit you, I like the airspeed on the upper left, with the tachometer near it. The altimeter should be in the area. I like the compass in the top middle, and the systems information gauges where ever it's handy to place them.David Paule>> How many of you guys who have completed Piets with glued in instrument > boards (panels) later wished you would have screwed it in instead? (So you > could easily install a different board with a different layout, etc). I > have made 4 different panels using Home Depot ply to get a layout I > "think" works, but until I fly this thing I can't know for sure.>> thanks>> rick________________________________________________________________________________Date: Sun, 14 Mar 2010 12:06:30 -0800Subject: Pietenpol-List: Front fuse question
Posted: Sun Mar 14, 2010 4:37 pm
RE: Pietenpol-List: Front fuse question
Posted: Sun Mar 14, 2010 4:45 pm
Mark,This is almost built to plans. What are the dowels for? That was an ideathat I got from Jim Boyer. They are locating dowels for the wood fire wall,which I probably had off and on 100 times! (seemed like it).Here you can see that eventually it all ties together with the fire wallglued on and hoop over the top, similar to Jack Phillips.Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) ________________________________________
Re: Pietenpol-List: Front fuse question
Posted: Sun Mar 14, 2010 4:49 pm
Posted: Sun Mar 14, 2010 5:42 pm
Subject: Re: Pietenpol-List: Front fuse question
Posted: Mon Mar 15, 2010 6:54 am
Steve Wittman had a 4 cylinder inverted Menasco on his race plane "Bonzo".--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009Ribs and tailfeathers doneusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/mena ... ______Date: Mon, 15 Mar 2010 06:00:00 -0700Subject: Re: Pietenpol-List: Front fuse question
Re: Pietenpol-List: Re: Front fuse question
Posted: Mon Mar 15, 2010 10:41 am
Subject: Re: Pietenpol-List: Re: Front fuse question
Posted: Mon Mar 15, 2010 3:52 pm
Real Piets don't need batteries ;o) (although some purists would say, 'real Pietsuse antifreeze').Very nice work though! Interesting that you have a rudder bar in the front cockpit.Does that mean you used individual pedals in the pilot's cockpit?--------Oscar ZunigaSan Antonio, TXAir Camper NX41CCRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 15 Mar 2010 11:13:52 -0600Subject: Re: Pietenpol-List: Front fuse question
Posted: Mon Mar 15, 2010 10:11 pm
No pedals! What do you think this is, a pedal plane! :-)Unfortunately very few folks will prop you now and thosethat will "give it a try" might wind up dead or worse.Clif>> Real Piets don't need batteries ;o) (although some purists would say, > 'real Piets use antifreeze').>> Very nice work though! Interesting that you have a rudder bar in the > front cockpit. Does that mean you used individual pedals in the pilot's > cockpit?>> --------> Oscar Zuniga> San Antonio, TX> Air Camper NX41CC>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ---Checked by AVG - www.avg.com12:33:00________________________________________________________________________________
Posted: Tue Mar 16, 2010 4:51 pm
Posted: Tue Mar 16, 2010 8:08 pm
Ending a sentence with a preposition is the kind of pedantry up with which I willnot put.DaveRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Wed Mar 17, 2010 11:15 am
Posted: Wed Mar 17, 2010 12:17 pm
