Pietenpol-List: Drill guide
Posted: Wed Apr 21, 2010 8:18 am
Does anyone have pictures of this drill guide that has been mentioned ora drawing diagram? Thanks.BrianSLC-UT-----Original Message-----
RE: Pietenpol-List: Drill guide
Posted: Wed Apr 21, 2010 8:40 am
BrianThis is the one I have used for almost ever hole so far.
http://westcoastpiet.com/drilling_holes ... --Original Message-----
Posted: Wed Apr 21, 2010 8:46 am
Brian,I think, with tongue in cheek, Chris was referring to the block of wood.Mine consists of a block of Oak, with various hole sizes drilled from mydrill press. You can locate the block with an awl or center punch, clamp into place, drill away.Gary BootheCool, CAPietenpolWW Corvair ConversionTail done, Fuselage on gear18 ribs done-----Original Message-----
Posted: Wed Apr 21, 2010 9:07 am
Original Posted By:>
BrianIn addition to the hardwood block design that Chris just mentioned I alsoused a "U" shaped jig made from copper water pipe fittings and stainlesssteel tubing. Complete info on the drill jig came from Clif Dawson. Here isa link.....
http://clifdawson.ca/Tools_and_Tips.html. The copper tubingjig works great for drilling the fittings on the spars. I have attacedphotos of both type drill jigs in use.Rick Schreiber> [Original Message]
Pietenpol-List: Re: Drill guide
Posted: Wed Apr 21, 2010 1:22 pm
Has anybody here seen this? Living in Colorado, I am VERY interested.
http://www.modelaengine.com/Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Drill guide
Re: Pietenpol-List: Re: Drill guide
Posted: Wed Apr 21, 2010 3:51 pm
Subject: Re: Pietenpol-List: Re: Drill guide
RE: Pietenpol-List: Re: Drill guide
Posted: Wed Apr 21, 2010 4:32 pm
Thanks guys for all the replies on the drill guide. The pictures speakfor themselves, now I get to go make me one.BrianSLC-UT
Posted: Wed Apr 21, 2010 5:10 pm
RickYour method is the same as I used. I just didn't want to weld up the jig. The coppertubing and fittings was simple and I had the raw material in stock. I likedthe fact that I could drill the strut fittings as a matched set on the drillpress. I then clamped then in place on the spar and drilled with the jig. Becauseof the set up the hole has to come out perfectly aligned.Rick Schreiber ----- Original Message -----
> Subject: Pietenpol-List: Drill guide>>> Does anyone have pictures of this drill guide that has been mentioned or> a drawing diagram? Thanks.>> Brian> SLC-UT>>> -----Original Message-----
