Re: Pietenpol-List: Gardiner's Corvair issue, or how not to cool the
Posted: Fri May 07, 2010 6:09 pm
Subject: Pietenpol-List: Re: Ethanol in Mogas-- more coming> > All stations in central NY are 10% ethanol. Traveled in SW Colorado last weekand all the stations I saw there were also 10%.> > --------> Jon Coxwell > GN-1 Builder> Recycle and preserve the planet> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 097#297097> > > > > > > > > > ________________________________________________________________________________Date: Sun, 9 May 2010 20:47:03 -0600Subject: Re: Pietenpol-List: Gardiner's Corvair issue, or how not to cool the Corvair in your Pietenpol
Posted: Sat May 08, 2010 9:03 pm
well that's one of the problems -it wasn't built to plans-it has quite a bit ofstretch and as I understood from a previous post the plans had wrong info anyway.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 8 May 2010 20:06:45 -0600Subject: Re: Pietenpol-List: Gardiner's Corvair issue, or how not to cool the Corvair in your Pietenpol
Re: Pietenpol-List: Mogas and carb ice - Stromberg carbs
Posted: Sat May 08, 2010 9:17 pm
Subject: Re: Pietenpol-List: Mogas and carb ice - Stromberg carbs
Pietenpol-List: Re: Weight.
Posted: Sat May 08, 2010 9:43 pm
O.K. You have to put the plane on scales, weigh it empty -- compute the emptyc.g. Sit in it, compute the c.g. and derive the pilot moment. Sit in the fronthole, compute the c.g. and derive the passenger moment. I found the passengermoment to be in error on my plane. The scales do not lie. I had to makea new motor mount and cowling and correct for short tach, carb heat and oil templines (not fun). Learn it.TomOn May 8, 2010, at 10:03 PM, skellytown flyer wrote:> > well that's one of the problems -it wasn't built to plans-it has quite a bitof stretch and as I understood from a previous post the plans had wrong info anyway.> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 148#297148> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Weight.
Posted: Sat May 08, 2010 10:06 pm
Well now that's what I need! gonna need a helper but I get it now.instead of usingmy weight or a pre-determined one at a certain distance.I can do it with thescales and get a real true figure. Probably something I can get done.I knowI am way too far forward CG. which is unusual.but that is a way to get some realisticfigures. thanks! RaymondRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 08 May 2010 23:25:38 -0400
