Pietenpol-List: The other Ohio Fly-in
Posted: Fri May 28, 2010 8:13 am
Hey Everyone,While Shad's "Fly-in" (Yes, i know it's not an official event) is coming up soon, I'd like to remind everyone that our EAA Chapter is hosting a fly in next weekend that should be of interest to a lot of you.Both of Frank Pavliga's Piets are generally on display, and a lot of other vintage aircraft typically show up. Also, you'll get to look at a lot of Corvairs in 'ground mode' i.e. still in cars, and Roy of Roy's Garage will be there to talk about his fifth bearing work and other aspects of Corvair conversion. He will also inspect & measure any components you bring to determine if they are OK for conversion.Here's the official announcement:EAA 82 is having it's 4th Annual "WINGS AND WHEELS FLY-IN" on Saturday and Sunday, June 5 & 6th at BARBER AIRPORT (2D1).The field is located approximately three miles north of Alliance, Ohio on State Route 225. There will be aircraft with automotive and alternative engines - CORVAIRS AND VOLKSWAGENS on display.Ther will be a pancake breakfast on Saturday and Sunday from 7 till 11 AM with lunch on Saturday from noon till 2 PM. This event is open to the public.There will be homebuilt aircraft ( KR-2S's, Pietenpols, an Afford-a- Plane), PRA #19 (Rotorcraft Chapter) will have trikes and a demonstrator, and Vintage and Antique aircraft (Waco 9, Fleet, Taylorcrafts) on the field. There will be a fleet of some nicely restored Corvair cars on display.There will be several Corvair engines and a "Roy's Garage" Fifth Bearing on display for those who are interested in using a Corvair in their project. Roy Szarafinski of Roy's Garage will be present to answer questions about his bearing and will gladly check your engine cases for proper tolerances before you start an engine rebuild.The fly-in hours will be Saturday... 7 AM - 4 PM and Sunday... 7 AM - 2 PM.For more information, contact Ron Willett @ 330-314-0075, Pete Klapp @ 330-388-2074, or Forrest Barber (FBO) at WWW.BARBERAIRCRAFT.COM.We can provide lodging for those who would be flying in for our event.Hope to see you all there!Kip Gardner________________________________________________________________________________Date: Fri, 28 May 2010 9:46:48 -0400
