Pietenpol-List: Re: Wing on!! W & B problem
Posted: Mon May 31, 2010 11:09 am
Original Posted By: "jhodnette"
I have also read both of them- they do make you yearn for a simpler time in aviation.--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wing on!! W & B problem
Posted: Mon May 31, 2010 8:48 pm
Harvey, I don't know whether these guys are still doing business or not, but in case you need a cylinder, they might be worth a phone call. I think they are in the general area of Denver (Fort Collins actually) Doesn't look like I can do a link, so you will have to cut and paste.
http://www.franklinengines.com--------Long flights, smooth air, and soft landings,GliderMike, aka Mike GlasgowRead this topic online here:
Re: Pietenpol-List: Re: Red Baron VS GN-1 AirCamper
Posted: Mon May 31, 2010 9:27 pm
Dan,When I flew my Piet with a Warner 145, the weight was more nose heavy than youwill experience, try it on a taxi run, if the girl takes off, which I know itwill. your in business. Be sides look where your elevator's position is, no droop.Pieti Lowell.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 31 May 2010 21:31:01 -0500Subject: Re: Pietenpol-List: Re: Red Baron VS GN-1 AirCamper
Re: Pietenpol-List: Re: Wing on!! W & B problem
Posted: Mon May 31, 2010 10:13 pm
We don't need no stinkin math!Clif> Fill the turtle with Helium [Shocked] Weigh it and do the math and see where the CG is. > Long flights, smooth air, and soft landings,> GliderMike, aka Mike Glasgow________________________________________________________________________________Date: Mon, 31 May 2010 22:15:44 -0500 (GMT-05:00)
Posted: Mon May 31, 2010 11:07 pm
Original Posted By: "GliderMike"
Hi Dan,I saw the video on youtube recently and I read that the owners daughter sings themusic. It is a pretty catchy little song!Read this topic online here:
Posted: Mon May 31, 2010 11:58 pm
Maybe extend the engine 14" on a heavy engine. MORE BEER
http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Wing on!! W & B problemDate: Tue, 01 Jun 2010 06:56:04 -0400
Pietenpol-List: Re: Lindbergh in WWII
Posted: Tue Jun 01, 2010 10:55 am
Original Posted By: "bluiewest1"
Subject: Pietenpol-List: Lindbergh in WWII Years ago I read The Wartime Journals of Charles Lindbergh which was just fascinating in how he flew P-38'sin the pacific and showed how the range of the P-38 could be extended greatly with high pitch and low rpms.He spent 5 months flying secretly as a civilian in the summer of 1944 and at age 42 flew 32 combat missionswith a few kills. (though he was supposedly just there on technical assignment and not supposed to fire guns !)[cid:image001.jpg(at)01CB0180.69F64520]________________________________________________________________________________Subject: Pietenpol-List: Re: Lindbergh in WWII
Posted: Tue Jun 01, 2010 2:20 pm
Original Posted By: "coxwelljon"
I have a very small crack on the top of my Model A aluminum head. Is there a wayto fix it or do I have to find another one? Thanks for your input..--------John HodnetteNX899JHRead this topic online here:
Posted: Tue Jun 01, 2010 2:46 pm
Raymond,I am building a GN-1 also with a Corvair engine. It has been my impression thatthe GN-1 is tail heavy so I have been concentrating on lightening up the rearas much as possible. Mine is a building and/or rebuilding of someone else'sproject so I am doing quite a lot of alterations. I would like to know a littleabout your motor mount (dimensions), I have to remodel my motor mount anywayand perhaps adjust it if necessary.Jon Coxwell--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:
Posted: Tue Jun 01, 2010 4:02 pm
John I'm in about the same boat.I took on the project D.J. Vegh had.it was lightenedsome around the tail I guess,but he also had stretched the fuselage dimensionssome to acommodate a long legged pilot like me.the engine has the flywheelat the rear of the case bolted to the harmonic ballancer and the Corvair manualmentions that causes the engine to have to be farther ahead for clearancei think.anyway if you want to e-mail me off list I could get you some lengthsfrom the firewall to various points.either way-in my worthless opinion-I'llbe glad to have the tank up top both because it will allow more head height,bemore at the CH so it will move less as fuel is burned off and hold more thanthe nose tank.on the plus side I'll have a beautiful aluminum nose tank for salesoon if you hear of anybody needing one.Read this topic online here:
Re: Pietenpol-List: Lindbergh in WWII
Posted: Tue Jun 01, 2010 5:30 pm
Original Posted By: Lloyd Smith
I will do some measuring and send some dimensions for comparison offline.Jon Coxwell--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 1 Jun 2010 20:54:07 -0400Subject: Re: Pietenpol-List: Lindbergh in WWII
Posted: Tue Jun 01, 2010 9:46 pm
