Pietenpol-List: FW: Bet you never saw one of these?
Posted: Sat Jun 26, 2010 7:18 pm
Original Posted By: Randy Farmer [mailto:r.l.farmer(at)comcast.net]
For awhile there, I thought maybe Dan had built one of these!Dan - I can only imagine.very happy for you!Gary BootheCool, CAPietenpolWW Corvair ConversionTail done, Fuselage on gear19 ribs done
Pietenpol-List: Re: Bet you never saw one of these?
Posted: Sun Jun 27, 2010 2:01 pm
Also, the rear member has to be cut if you put one in each side. I'd put bothsides together without the 1" piece, cut the longerons with the necessary miterand put the rear piece in when putting the two sides together.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Bet you never saw one of these?
Posted: Wed Jun 30, 2010 11:19 am
Original Posted By: "flea"
> One additional suggestion. Sand the glaze off your sheet of gusset materialbefore you cut out all the gussets! This will save you a lot of sore fingertipsif you have to do it later.> Tom Stinemetze> N328X> Yeah, that sanding tip is a biggie... should be tip #1, but I forgot about it...again. I ended up sanding every gusset individually with emery boards. Itreally wasn't too bad, but I wish I had just sanded my sheet before I cut it.--------Mark ChouinardFinishing up Wings - Working on Center SectionRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Bet you never saw one of these?
Posted: Wed Jun 30, 2010 1:09 pm
j_dunavin wrote:> HA can you imagine if you would hit a dear with that?! [Shocked]I never sausage a thing.Sorry, "bet you never saw one of these" + "imagine if you hit a deer with that"= processed meat jokes. I'll go back to my room now.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 30 Jun 2010 11:34:42 -0700 (PDT)
RE: Pietenpol-List: compass location, panel layout
Posted: Wed Jun 30, 2010 1:50 pm
And put your stick in level flight position. Moving the stick around canalso move your compass, by enough to get you good and lost.Jack PhillipsNX899JPRaleigh, NC _____
Posted: Wed Jun 30, 2010 2:08 pm
Posted: Wed Jun 30, 2010 2:41 pm
Original Posted By: H RULE
Pietenpol-List: Re: One Down!
Posted: Wed Jun 30, 2010 2:55 pm
Don't know if youre still working down this path, but I remembered seeing this photo of a shroud around the carburetor and some of the intake apparently to avoid carb-ice. Its the only application like this Ive seen but thought Id bring it to your attention in case it could help. http://www.westcoastpiet.com/images/Che ... _4.jpgRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: One Down!
