Pietenpol-List: landing gears
Posted: Tue Aug 03, 2010 9:48 am
Original Posted By: Jim Boyer
Here's my $.02 cents on the different landing gears. (and worth everypenny!)"Jenny gear" is significantly heavier due to that big 'ole axle, and one hasto devise some clever means to keep the axle from rotating if one usesbrakes. From all my reading of old newsletter back issues and FAA accidentreports, and my own experience this spring I believe the Jenny gear hasproven itself to be the stronger design. I do not believe it is easier tomake, on the contrary, I think it is one of the trickiest parts of the wholeproject. Welding up the split gear would be much easier in my opnion."split gear" (shouldn't really call it a cub gear because it predated thecub) is much lighter, easier to make and simpler to install brakes on.This gear also won't catch tall weeds or crops in an off field landing andflip one over as easily as the axle on the Jenny style will. Though LarryWilliams claims his Jenny gear axle saved him from nosing over in his offfield experience when he taxied into a hidden hole and the only thingkeeping the plane from going over was the axle catching on the edge of thehole.As beautify is in the eye of the beholder, I can't say which is prettier. Ilove the nostalgic look and strength of the Jenny gear, but I also love asplit type gear with big wheels like Don Emch's, and you see that a lot inold pictures. Bernard Pietenpol didn't build too many with the Jenny gear before he wentto the split type gear and never looked back, mainly because he was BIG intosaving weight, and he claimed the split axle didn't catch weeds as much inovergrown fields which they landed in a LOT.I'm using the Jenny gear because its' nostalgia and strength.Douwe________________________________________________________________________________Date: Tue, 3 Aug 2010 15:18:24 +0000 (UTC)
