Pietenpol-List: Original Air Camper & Sky Scout Builders Manual
Posted: Tue Aug 03, 2010 10:07 pm
il>For those of you building per-the-plans split gear - my gear is straight out of the 1932 plans (except for the wire wheels and brakes) and uses a single 6' strand of bungee on each side.- When the bungee broke on Sunday the 24th, I realized that it is a single point of failure.- Fortunately, the safety cable worked as designed.- For the sake of redundancy I plan to replace the single strand system with donuts.- An additional benefit is that donuts are easier to install.-I'll fabricate the donuts using the neat safety wire clamp tool thingy we bought at oshkosh and use 1/2" bungee.- I'll test a couple of donuts to 500 or 600 lbs before I actually use them on the plane.- If successful, I'll put enough of the donuts on each side to handle a 4 or 5 G landing.Thought about replacing the whole mess with springs but I like the rubber bands.- Will let you know how it works out.Axel--------Kevin PurteeNX899KPAustin/Georgetown, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... 1#307521le, List Admin.=0A=0A=0A ________________________________________________________________________________Subject: Pietenpol-List: Original Air Camper & Sky Scout Builders Manual
