Pietenpol-List: Rust Protection Question
Posted: Wed Aug 18, 2010 7:56 pm
Original Posted By: Matthew VanDervort
Yet another question for my "list friends".With your wing/center struts,gear and various horns, how are you protecting against rust and corrosioninternally after painting? Prior to painting mine rust quickly if I don'tcoat with oil.Thanks,Jack ________________________________________________________________________________
Pietenpol-List: struts
Posted: Wed Aug 18, 2010 8:28 pm
I was planning on linseed oil but haven't done any "real" research yet but a few quick google searches have turned up promising resultsSent from my iPhoneOn Aug 18, 2010, at 8:56 PM, "Jack" wrote:> Yet another question for my =9Clist friends=9DWith your wing/center struts, gear and various horns, how are you protecting against rust and corrosion internally after painting? Prior to painting mine rust quickly if I don=99t coat with oil> > Thanks,> > Jack> > > > > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: struts
Posted: Wed Aug 18, 2010 8:59 pm
I don't know if anybody is needing a set but there is a set of BC12D struts I believeit said they are on Ebay aircraft parts list right now.I do not know thatthey are suitable for use to make Piet struts but I would sure check it outif I didn't already have mine made./on another note if anybody has any experiencehooking up a Datcon tachometer I'd sure appreciate a e-mail off list. I'mhaving some trouble figuring out how to program mine. RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: RE: Pietenpol-List: remote mounting 0200 air box
Posted: Thu Aug 19, 2010 5:59 am
Are you talking about the cowling? Those are Cleco's, holding the piecestogether until I could rivet them. Everything on the cowling is rivetedtogether.Jack PhillipsNX899JPRaleigh, NC _____
RE: Pietenpol-List: Re: Rust Protection Question
Posted: Sat Aug 21, 2010 12:37 pm
Thanks for the note Kevin, that's what I plan to do...JackDSM-----Original Message-----
Posted: Sat Aug 21, 2010 3:20 pm
Original Posted By: "Dan P"
Has anyone flying used a cork/rod type gauge successfully in their centersection tank? Was wondering if you can see it while strapped in.Thanks,JackDSM________________________________________________________________________________Subject: Pietenpol-List: Re: Rust Protection Question
Pietenpol-List: Re: Cork Fuel Guage
Posted: Sat Aug 21, 2010 3:26 pm
Bare metal. Epoxy primer before painting is hard to beat.--------Dan PlettRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Cork Fuel Guage
Posted: Sat Aug 21, 2010 3:46 pm
Original Posted By: Harvey Rule
My sight glass hangs down below the wing. I don't have a picture but I did findthis from flying-squirrel that is similar to mine. Easy to see while flying.--------Dan PlettRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/fuel ... __________
RE: Pietenpol-List: Cork Fuel Guage
Posted: Sat Aug 21, 2010 4:16 pm
Original Posted By: jack(at)textors.com
I have been using just such a gauge now for 5 years and I find it to be quite satisfactory. I would however suggest using a small tube in the gas cap to keep the rod from leaning over as mine does all the time.Someday I'm going to change that and fix it. I did measure and paint the end of the rod white to indicate when I am running low on fuel. I gave myself a few extra gallons before total empty. just to be on the safe side.You may want more.Just paint lower for more fuel at the end.
Posted: Sat Aug 21, 2010 4:26 pm
I've got one. Why would you have trouble seeing it?See it hanging down in front of the fornt cockpit windshield?Jack PhillipsNX899JPRaleigh, NC _____
Has anyone flying used a cork/rod type gauge successfully in their center section tank? Was wondering if you can see it while strapped in.Thanks=2CJackDSM ________________________________________________________________________________
