Re: Pietenpol-List: 40 hour fly-off, state of model A
Hi Ryan,-I've tried that........nothing.-Dan HelsperPoplar Grove, IL.-----Original Message-----
Subject: Re: Pietenpol-List: 40 hour fly-off, state of model AI don't know if you've done this or not, but what about starting the engineand then raising the tail and setting on a sawhorse/blocking get it tolevel, and see if that will duplicate the issue....RyanSent from my iPhoneOn Aug 29, 2010, at 3:20 PM, helspersew(at)aol.com wrote:Doug,My engine is running like a top, but I can still detect the sputtering onfinal at very low idle. I still can't figure out why. Like yesterday, nosign of induction condensation, but it still happened. Runs fine as soon asI coast out and on the ground.Dan HelsperPoplar Grove, IL.-----Original Message-----
Subject: Re: Pietenpol-List: Re: Looking for a pietI think the engine is an 85 and has had a recent top overhaul. The wing span is longer than standard but I don't know by how much. The fuel tank is just behind the firewall and I believe about 18 gal. I have never flown in it but the observed performance seems to be very good. Hope this helps a little.Jim BallewPiet N38BIn a message dated 8/29/2010 5:13:48 P.M. Central Daylight Time, hangar10(at)cox.net writes:--> Pietenpol-List message posted by: "K5YAC" Since Dan brought it up, I'll provide what details I can on Roger White's airplane. I have been hesitant on offering this info, but I spoke to him Friday night and he said he wouldn't mind me posting some information here. Roger completed "Precious Pete" in 1996. While it's not an exact Pietenpol reproduction, it apparently flies real good according to those who haveflown it and it looks neat. If I remember correctly, he has a long steel tube fuse, metal empennage, a single point wing attach (rather than the pair of cabanes shown in the plans), steel gear and a Continental A-65 with metal prop for power. I don't know much more on the specifics other than I think he was asking $15,000. That may be negotiable, not sure what he would take. For those that don't know Roger White... he is a master homebuilder (EAA #41) with several aircraft to his credit and a super nice guy. He has built several types, such as the Wittman Tailwind, Cassut Racer and a Glassair to name a few... he is currently working on a Corvair powered Bolkow Junior. Jim Ballew is a good friend of Roger's that lives on the same field... he also frequents the boards here. Perhaps he can offer more details or clarification.--------Mark ChouinardWings and Center Section framed up - Working on EmpannageRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/p926 ... ___Subject: Re: Pietenpol-List: 40 hour fly-off, state of model ADate: Sun, 29 Aug 2010 19:53:22 -0400
Pietenpol-List: Re: 40 hour fly-off, state of model A
Original Posted By: "tkreiner"
Subject: Pietenpol-List: what it is like to fly a Pietenpol---told thru friendof Rob Bach, GOOD READFellow Pietenpol enthusiast, builder, pilot, and owner Rob Bach gave this unique lady her tailwheel endorsement and let herSOLO his Pietenpol and she posted this GREAT story about her experience.Thanks Rob for sharing the gift of open cockpit flying and getting this lady a logbook entry and experience that she will never forget.Mike C.http://www.myskymom.com/2010/07/25/heav ... rsement/To me this what our kind of flying is all about. Build, learn, fly, share, infect others and don't look back.________________________________________________________________________________Subject: Pietenpol-List: Re: 40 hour fly-off, state of model A
Re: Pietenpol-List: Re: Rib drawing
Original Posted By: Dan Yocum
Dan,Not sure which carburetor you're running, but my experience of having owned a ModelA, along with a lot of experience with engines and carburetors in general,leads me to believe the issue is in carburetion. In general, a mixture that becomes slightly rich will make the engine run rough,where a lean mixture will make the engine produce a light exhaust popping sound(or in my 40-ish year old memory of this, it the other way around?). Are you able to pull a plug immediately after landing to see what the color ofthe electrode is? For a rich mixture it will be black to sooty, for lean itwill be gray to white, and for close to stoichiometric, it will be chocolateyin color. Due to the nature of "coloring" the plug, it may take several minutesof continued operation under the condition you experience to produce a visibleresult on the plug... and an inexact or short run could be misleading.Hope this helps.--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Rib drawing
I cut little blocks out of the thickest plexi I could get - about 1/4" - and super glued them to the plexi sheet. Works great and those blocks are unmoveable (unfortunately). -- Dan Yocumyocum137(at)gmail.com"I fly because it releases my mind from the tyranny of petty things."On Aug 29, 2010, at 9:24 PM, Rick Holland wrote:> Or get a piece of plexiglass from Home Depot to lay over the rib drawing (and that you nail your rib jig blocks to).> > rick> > On Sun, Aug 29, 2010 at 3:00 PM, K5YAC wrote:> > In order to keep the original print in good shape, my wife suggested that I use carbon paper and trace the original print to the MDF. At first I thought that would be difficult, but carbon paper is cheap (especially if you have an Office Depot or Staples nearby) and the MDF is smooth so I gave it a try. It only took about 30 minutes and I had an exact reproduction on my jig. This really helped a lot when it came to placing blocks and cams for aligning the pieces.> > Just figured I'd share that since it worked out good for me... I chose to glue and nail my ribs. If you prefer to clamp, just look around as there are several other cool variations around here.> > --------> Mark Chouinard> Finishing up Wings - Working on Center Section> > > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 535#310535> > > > > Attachments:> > http://forums.matronics.com//files/wing_jig_342.jpg> http://forums.matronics.com//files/wing_jig_2_165.jpg> > > > > ==========> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> ==========> http://forums.matronics.com> ==========> le, List Admin.> ="_blank">http://www.matronics.com/contribution> ==========> > > > > > > -- > Rick Holland> Castle Rock, Colorado> > "Logic is a wreath of pretty flowers, that smell bad" > ________________________________________________________________________________Date: Mon, 30 Aug 2010 09:23:34 -0400 (EDT)
Dan,Recently, I had the opportunity to fly Allen Rudolph's old Piet, now owned by FrankPavliga. Quite a flying machine! At Brodhead it was refitted with the enginethat used to be in Jack McCarthy's Piet. When I throttled back I seemedto remember some light popping and sputtering that seemed to continue throughfinal. In fact, I noticed it enough to ask Frank and Andrew King about it afterlanding. Neither seemed to be very concerned. I know Andrew watches thislist, so maybe he'll chime in. By the way, I really think if I were to build another Piet I'd do my best to replicateTHAT one. What a beautiful flying airplane! Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: The purist and seat belts
You probably also did not use cotton muslin or Irish linen to cover yourairplane. Dacron?Jack PhillipsNX899JPRaleigh, NC _____
Pietenpol-List: Re: The purist and seat belts
Original Posted By: "ldmill"
The Model A will sometimes make a fluttering sound on final, maybe due to someof the things mentioned above, airflow driving the prop etc. As long as it idleswell on the ground I don't think it should be a problem, hard to really judgewithout hearing it, but that is what I would lean towards.-Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: The purist and seat belts
Re: Pietenpol-List: Re: 40 hour fly-off, state of model A
Perhaps Im thick or something but is there something different in those printsthat would make a plane built from them a more beautiful flying airplane? Sincehe was referring to flying Allen Rudolph's old Piet and said, if I were tobuild another Piet I'd do my best to replicate THAT one, I assume there was somethinghe noted about THAT airplane.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 3 Sep 2010 14:18:41 -0500Subject: Re: Pietenpol-List: Re: 40 hour fly-off, state of model A
>> yocum137(at)gmail.com>>> I disagree. I think 29" on-center is a better dimension. It matches the 29"> between the attach points on the fuse. And even though WW thinks it's a> misguided belief that one can shift the wing back and forth to correct for> CoG issues, a perfect parallelogram *will* allow for such shifting. I do> agree with his assessment that the attach points for the diagonal cabanes> should be heavy duty, permanent jobs, if not welded, but that's a different> issue.>> Dan>> --> Dan Yocum> > yocum137(at)gmail.com> "I fly because it releases my mind from the tyranny of petty things.">> On Aug 28, 2010, at 5:46 PM, Ryan Mueller > rmueller23(at)gmail.com> wrote:>> rmueller23(at)gmail.com>> >> > The 27 3/4 is the important dimension. Go ahead and use it!> >> > Ryan> >> > Sent from my iPhone> >> > On Aug 28, 2010, at 4:35 PM, JGriff > jgriffith19(at)comcast.net> wrote:> >> jgriffith19(at)comcast.net>> >>> >> I received my plans and am about to construct my rib jig on 3/4" MDF. I> didn't give much thought to using the supplied rib drawing and instead was> going to plot out the shape because so many posts in the archive say not to> use it since the drawing is off due to the xerox reproduction. I just double> checked the drawing and it seems pretty accurate. The chord is 58" which I> assume is correct because it doesn't include the leading or trailing edge.> Also the 27 3/4 inch dim given between the spars is spot on. Has the drawing> improved from years past? I'm thinking of using it - has anyone else used it> instead of plotting it out?> >> Thanks.> >> Jamie> >>> >>> >>> >>> >> Read this topic online here:> >>> >> > http://forums.matronics.com/viewtopic.p ... 413#310413> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> &tor?Pietenpol-List" target=_blank>http://www.matronics.com/Navigator?Piet - MATRONICS WEB FORUM href="> http://forums.matronics.com/" target=_blank>http://forums.matronbsp;> - List Contribution Web Site -http://www======================>>> *>> ==================================> >http://www.matronics.com/Navigator?Pietenpol-List> ===================================ums.matronics.com">http://forums.matronics.com> ===================================http://www.matronics.com/contribution"> ... ntribution> ==================================> *>> *>> *>>-- Rick HollandCastle Rock, Colorado"Logic is a wreath of pretty flowers, that smell bad"________________________________________________________________________________Subject: Re: Pietenpol-List: 40 hour fly-off, state of model ADate: Mon, 30 Aug 2010 07:21:42 -0400
