Pietenpol-List: The Stewart System
Posted: Thu Sep 02, 2010 1:50 am
Original Posted By: "Jack"
Hi all,-I used the Stewart System and would recommend it. The best thing about it was the fact that it is all water soluble, and everything cleans up with water. During the painting of an airplane from start to finish, one must clean brushes, guns etc countless times. I simply walked over to the sink and turned on the water. No stink, no fumes, no harmful solvents I believe the glue to be superior to the other systems. Watch the YouTube videos that Stewart has posted. Very easy to use. Their final color coats are a true two- part paint system and is equivalent to any polyurethane when cured. No fresh air respirator needed.-Dan HelsperPoplar Grove, IL.=0A=0A=0A ________________________________________________________________________________
Re: Pietenpol-List: The Stewart System
Posted: Thu Sep 02, 2010 9:55 pm
Original Posted By:> helspersew(at)aol.com
Shad,Yes it is the same. The Stewart Bros bought the AFS line a few years back (four or five) and seem to have taken it to the next level.-john-John HofmannVice-President, Information TechnologyThe Rees Group, Inc.2424 American LaneMadison, WI 53704Phone: 608.443.2468 ext 150Fax: 608.443.2474Email: jhofmann(at)reesgroupinc.comOn Sep 2, 2010, at 7:46 PM, shad bell wrote:> Is stewart system the same as AFS brand Cecobond? Dad used the cecobond, waterbased glue which is now Ecobond I believe. Bluish green in color and can be thinned with water for sealing the weave if desired. Works pretty good, but I am not sure if it is compatible with other paints like dope or polyurethanes. We used latex so the whole process was cleaned up with H2O. It has a good aftertaste when washed down with a cold miller lite as well.> > Shad> > --- On Thu, 9/2/10, helspersew(at)aol.com wrote:>
> Subject: Pietenpol-List: more info on the Lee Bottom Fly-in, Last weekendin September, Southern IN >Aerospace Corporation]" >> I am planning on flying my Piet there Shad on Friday, arriving sometimein the afternoon weather permitting> then leaving Sunday before 11 am. >> It is a great event. I was there in 2008 and there were two otherPietenpols there, one from Northern Indiana. > I hope we can make a good showing of Piets. >> For a taste of what the Lee Bottom Event is like go HERE: http://www.youtube.com/watch?v=r91F95FIIZo>> THEN to find out details about the fly-in go HERE: http://www.leebottom.com/>>> If you fly in you should be a taildragger.........this really isn't aC-172 event at all, they have specific> guidelines at this site about the fly-in. FAQ's: http://www.leebottom.com/FLY%20IN%20FAQ ... ___Subject: Pietenpol-List: The Stewart SystemDate: Thu, 02 Sep 2010 18:50:01 -0400
> > Hi all,> > I used the Stewart System and would recommend it. The best thing about it was the fact that it is all water soluble, and everything cleans up with water. During the painting of an airplane from start to finish, one must clean brushes, guns etc countless times. I simply walked over to the sink and turned on the water. No stink, no fumes, no harmful solvents I believe the glue to be superior to the other systems. Watch the YouTube videos that Stewart has posted. Very easy to use. Their final color coats are a true two- part paint system and is equivalent to any polyurethane when cured. No fresh air respirator needed.> > Dan Helsper> Poplar Grove, IL.> > > > " rel=nofollow target=_blank>http://www.matronics.com/Navigator?Pietenpol-List> et=_blank>http://forums.matronics.com> llow target=_blank>http://www.matronics.com/contribution> > > > > ________________________________________________________________________________
