Pietenpol-List: Review of Blakesburg Antique Aircraft Association flyin
Posted: Tue Sep 07, 2010 7:31 pm
Original Posted By: "ldmill"
>I have my fuselage blocked up and my axles set where the longeron will be >at 51in. The 56 looked a bit narrow so i moved the wheels out to 60in. To >me this still seems narrow. I really enjoy the building process but will be >much glad when this gear is done. Steve S Jack, Steve was asking about the split steel gear, not the wood Jenny-style gear as you have on your plane. On my plans, the split gear is shown as 56" center to center between the wheels. However, the wheels shown on the plans are much more like ATV tires than motorcycle wheels. I think that Don Emch has split gear and motorcycle tires, maybe he will chime in and discuss how he built his landing gear.>> I see no reason not to make that dimension a bit wider to give better > stability while taxiing and during take-off or landing roll-outs...>> Steve, maybe you should block up your fuselage with saw horses (or > whatever it takes) to the proper stance and height to the top longeron > that the plane will have while sitting on the ground, and then take the > measurements for your landing gear so that you can build it to make it sit > like it should.>> --------> Billy McCaskill> Urbana, IL> tail section almost done, starting on ribs soon>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 711#311711>>> ________________________________________________________________________________Subject: Pietenpol-List: Review of Blakesburg Antique Aircraft Association flyin
