Pietenpol-List: Ford or not
Posted: Thu Sep 30, 2010 2:27 pm
Original Posted By: "bender"
Dan,When you put the engine together did you drill the cam gear for centrifugal lubrication?Several 1/16" diameter holes drilled from a tooth gullet inwards tothe inside lip of the cam gear face/flange allow all the oil coming off the mainto reach the gear contact area. Mine is full pressure to the mains so I drilleda .050" hole in the capped end of the main feed tube to the front(now rearmain). I drilled the holes as suggested and have a TON of oil in tooth contact...tothe point that I somehow have oil working out of the tach connection.Oil under pressure(30psi) sprays from this hole onto the backside of the cam gear.Centrifugal actions carries it to the holes which then apply it to the gearcontact area. You are welcome to stop up to Ft Atkinson anytime to look at what I did and comparenotes.--------PAPA MIKERead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ___Subject: Pietenpol-List: Ford or not
