Pietenpol-List: flying qualities--Jack's comments and my thoughts
Posted: Tue Oct 05, 2010 7:22 pm
Subject: Pietenpol-List: flying qualities--Jack's comments and my thoughts I totally agree with Jack's comments about flying the Pietenpol. I have about800 hours tailwheel timeand to me the Pietenpol is easier to fly than a J-3 because the deck angle seemshigher on the Cub unless youput cushions under you (which I did for my recent flight review in a cub) but Itoo liked landing Ryan and Jess's Cub very much with the Cub tires. Once in the air they pretty much all fly thesame except the Model A's whichfly just like the Continental ones but pretend you're flying in semi slow flightwhere the controls aren't quiteas crisp because your air speed over the controls isn't as high. I believe that my deck angle is LOWER than Jack Phillip's Pietenpol because hehas taller wire wheels than mineand a longer nose because he's got the long fuselage and I have the short fuselage.I purposely setup my fuselage to have a lower deck angle because I wanted bettervisibility over the nose. I generallycan make smooth landings but like Jack said it isn't the kind of plane you canwrack up 3 consecutive greasers normallybut I would say overall it is a very easy airplane to land. With an adult passenger in the front seat who has WIDE SHOULDERS I always ask themto push to one side or the otheron final-----not to duck mind you but to shift to the right side (since my throttlelinkage is on the left and I don'twant them binding that with a coat or arm) and that greatly helps me see centerlineof the grass or hard surface beforethe flare begins. Another reason to just limit riders to petite ladies or youngerpeople:)) I did give a 170 pound retired gent a ride a few weeks ago and it was no problemas he listened thru the intercom to myrequest on final to shift right and I have a ritual where I takeoff on the pavedsurface, land on the sod surface when hauling rides because you get better acceleration on pavement, less drag. Onlanding you get the nice softness of theforgiving sod if you're not 100% in line with the runway upon touchdown and thedeceleration is faster than if on pavementand tailwheel steering is less sensitive on grass than pavement....still have flownrides off of hard surface with no issuesbut if there are gusty winds it is no fun to fly a Pietenpol, even alone. Mike C. (finally surfacing again somewhat)________________________________________________________________________________
