Pietenpol-List: off shore tubing
Posted: Sun Jan 09, 2011 8:16 pm
Hello everyone on the Piet list. I just finished doing some machine work on the 4130 chromoly tubing that I received from my supplier in Portland Or.for axles It is chinese in origin and although my supplier assured me that it was made to the same astm spec. as the USA made stuff is, the following is what happened. I machined my axles 16 inches in from each end approximately .0025 to make them round which they are still not perfectly round and in the process of cutting the outside surface off discovered a crack that ran almost 2.5" length ways in the tubing. I am very diapponted in the quality of this off-shore tubing and will be replacing this tubing hopefully with USA made on Monday. Also from previous experience, this metal did not cut butter smooth like the rest of the 4130 that I am accustomed to using. We tried many combinations of cutting tools and different speeds to no avail. Very difficult to work with.Ernie MorenoPiet 2431 ----- Original Message -----
