Pietenpol-List: Extra wing width
Posted: Fri Jan 14, 2011 9:05 am
Original Posted By: "integritywood"
Hey Guys... are the Forest Lovely radiators one row or two row radiators..?JeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Extra wing width
RE: Pietenpol-List: Extra wing width
Posted: Fri Jan 14, 2011 11:46 am
Kim,I made my centersection 3' wide, which required modifying the cabane strutattach fittings (not a big deal - just something to think about, and itallows for a larger fuel tank in the centersection). I would agree thatadding a foot to each wing is probably a good thing, but there are somethings that should be considered.1. I would move the lift strut attach points outboard so the strutscontinue to hit the middle of the spars. This keeps the lift pretty muchcentered on the struts and reduces bending stress in the spars. 2. If you make the wings longer, you might seriously consider adding athird or even a fourth bay of drag wires and compression struts. The dragwire angles involved with the standard Pietenpol wing are more acute thanany other airplane I know, and this tends to really increase the loads inthe cables. Most airplanes have the drag wires cross the anti-drag wires atpretty close to a 90=B0 angle, but the Pietenpol tends to cross at more like a45=B0 angle. Making the bays longer just exarcerbates this.Other than that, I can=92t think of any problems that making the wings a footlonger would cause.Good luck!Jack PhillipsNX899JP =93Icarus Plummet=94Raleigh, NC-----Original Message-----
Posted: Fri Jan 14, 2011 12:37 pm
Original Posted By: gcardinal(at)comcast.net
Re: Pietenpol-List: Extra wing width
Posted: Fri Jan 14, 2011 2:29 pm
Original Posted By: Kimball Isaac
I'm progressing well on my ribs (one a day) and am thinking about building thewing center section next. Can anyone direct me to a sight that has some goodpictures of this part being built?Thanks--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 14 Jan 2011 14:03:54 -0800Subject: Re: Pietenpol-List: Extra wing width
