Pietenpol-List: Need some tunes in the garage.
Posted: Fri Feb 11, 2011 9:01 pm
Original Posted By: Andrew M Eldredge
Subject: Pietenpol-List: Need some tunes in the garage.
Re: Pietenpol-List: Need some tunes in the garage.
Posted: Fri Feb 11, 2011 9:19 pm
I recommend the Andrew's sisters, benny goodman, and Billie holiday!Sent from my iPhoneOn Feb 11, 2011, at 10:01 PM, Andrew M Eldredge wrote:> You know what's boring? Ironing down the edges of tapes is boring.> > -- > Andrew Eldredge> Sahuarita, AZ> > ============================================================================================================================================> ________________________________________________________________________________Date: Fri, 11 Feb 2011 23:02:41 -0500
Pietenpol-List: Re: Need some tunes in the garage.
Posted: Sat Feb 12, 2011 12:52 am
Original Posted By: "Dangerous Dave"
Hi all....I have also posted this on a Corvair forum. Thought someone here mayknow something too. I have had the offer of a MA-3SPA Carb. Part No. 10-4115 Serial No. AV21410 FAAPA for my Corvair. This Carb has just been removed from a Cessna 150 with anO-200. The owner has fitted a ROTEC throttle body carb to it.I know WW says to use the MA-3SPA 10-4894. I believe the 10-4894 is off the O-200?Does this mean this carb I have been offered will work the same? Can anyoneeducate me as to what the difference is?Maybe this one could be rebuilt as a 10-4894?Thank you one and all for any help as it is a good price and comes with the airbox/filterand cables I believe.ScottyAustralia--------ScottyTamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Need some tunes in the garage.
Re: Pietenpol-List: Re: Need some tunes in the garage.
Posted: Sat Feb 12, 2011 9:00 pm
Subject: Re: Pietenpol-List: Re: Need some tunes in the garage.
Re: RE: Pietenpol-List: Tail Wheel Spring Question
Posted: Sat Feb 12, 2011 9:10 pm
Subject: Re: RE: Pietenpol-List: Tail Wheel Spring Question
