Pietenpol-List: Tail Wheel Weight FYI
Posted: Sun Feb 13, 2011 9:03 am
Weighed my Scott tail wheel at 4.9 pounds. The Matco is 4.75 pounds pertheir site. Both 6" solid rubber. My leaf springs cam in at 2.5 pounds.JackDSM________________________________________________________________________________
RE: Pietenpol-List: Tail Wheel Weight FYI
Posted: Sun Feb 13, 2011 9:26 am
Try the AS&S Homebuilt Special tailwheel. I think it weighs around 3 lbs(4" diameter). And the Pietenpol A-Arm Coil Spring configuration is about apound or two lighter than a leaf spring. I cut 2 lbs off my tailwheelweight by using that design with the 4" tailwheel instead of a 6".Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
Posted: Sun Feb 13, 2011 9:28 am
Re: Pietenpol-List: Tail Wheel Weight FYI
Posted: Mon Feb 14, 2011 5:24 am
Tail Wheel Weight FYI ----- Original Message -----
Posted: Mon Feb 14, 2011 5:26 am
Tail Wheel Weight FYIRe: AS&S Homebuilt Special tailwheel. Jack, I am very interested in the tail wheel you mentioned. I can't find it in the AS&S listing for tailwheels. How do I find it? Chuck in Winston-Salem. ----- Original Message -----
Posted: Mon Feb 14, 2011 6:11 am
http://www.aircraftspruce.com/catalog/l ... el.phpJack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
Posted: Mon Feb 14, 2011 2:42 pm
Tail Wheel Weight FYIThanks, Jack, but for $130 I believe I can stand an extra 2 pounds back there. If I have to, I'll move the wing back a fraction. ----- Original Message -----
