Pietenpol-List: Gross weight of pietenpol
Original Posted By: "pilotjkl"
B & B Aircraft Supplies. PO Box 37, Gardner, Kansas 66030, Phone (913) 884-5930. I bought all my turnbuckles for $7.50 each.-----turnbucklesThis I copied a few days back...saved for hard times!--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Gross weight of pietenpol
RE: Pietenpol-List: Gross weight of pietenpol
It's Experimental, and you are the manufacturer. The Gross Weight on thedataplate is whatever you say it is.I think the original was 1090 or something like that. If you go much abovethat it wouldn't hurt to have an engineer look at what you've built.Impossible to say without seeing what changes have been made to the design.Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC-----Original Message-----
Pietenpol-List: Re: Gross weight of pietenpol
Original Posted By: airlion
Thanks for the reply, I thought it was established by the designer through stresstesting JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 13 Feb 2011 17:23:59 -0800 (PST)
