Pietenpol-List: split landing gear
Posted: Fri Mar 04, 2011 7:06 pm
Original Posted By: "heavyliftpilot"
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________________________________________________________________________________Subject: Pietenpol-List: split landing gear
Posted: Fri Mar 04, 2011 7:21 pm
Hi, I'm new to this forum, but not to the aviation field. I recently obtaineda piet and it has the 'split axle' landing gear. The builder put spruce strips(similar to the turtleneck) on the underside of the fuselage...and it causedsome interference problems with the bungee cords. I noticed that the struts(with the bungees on them, could actually be flipped around, so that the bungee'sare near the wheels. has anyone had a problem with this? and flipped thebungee struts around???? thanks, jamesRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 4 Mar 2011 17:30:39 -0800 (PST)
Pietenpol-List: Re: split landing gear
Posted: Sat Mar 05, 2011 8:08 pm
I don't understand which one you are referring to Jack..........the one under thehoriz stab??--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: split landing gear
Posted: Sat Mar 05, 2011 9:09 pm
Original Posted By: "Jack"
Well it doesn't look like you have got any responses so maybe I'll give it a shot.ifyou are talking about the cub style gear maybe you could consider replacingthe bungees with springs.several have done that and I think it would giveyou more clearance.there has been discussion of it in the past and no doubt thereare some good references in the archives though I never got to where I couldfind stuff that way.where are you located? welcome anyway.RaymondRead this topic online here:
RE: Pietenpol-List: One of Those Days...
Posted: Sun Mar 06, 2011 8:23 am
Jerry, I was just voicing the frustration. I was referring to the fittingsthat attach the vertical and horizontal stabilizers to the fuselage, bothfront and rear. If you scroll down from herehttp://textors.com/PietProject.html you can see pictures under tail group.Even after thinking through the process, figuring for fabric thickness etc,I still messed up. It won't be the last time I'm sure. In this picturehttp://textors.com/DSCN4181.JPG you can see the top two rear fittings, whichif used wouldn't allow enough room for the nuts that secure the bottom twofittings. They will be too close to the fuselage side. So I plugged thestab, re-drilled then re-made the top fittings moving the bolts out. Prettymuch had to do the same to the front fittings. Oh well.JackDSM _____
Posted: Mon Mar 07, 2011 8:41 am
Subject: RE: Pietenpol-List: Jack Cox obitWhat an incredible aviation author with encyclopedic knowledge of homebuilt airplanes and antiques. Jack Cox was a very AVID supporter ofthe Pietenpol movement and spearheaded a multi-page article about our 70th Anniversary Gathering of Pietenpols at Oshkosh in 1999 andfortunately Jack Phillips and I were able to with speak with Jack Cox and his wife Golda by Jack's Pietenpol in 2009 by Jack's Pietenpol.Jack was a very humble and unassuming man but a powerful aviation author and editor in Chief of Sport Aviation magazine and contributing authorfor many years as well as his own excellent magazine Sportsman Pilot of which I have the latest copy of in my car and was reading it over the weekend.Thank you for letting us know about Jack's passing. Thankfully though Jack is gone his publications and articles will live on forever as a great tribute to the legacy of his life.Mike C.PS-very much like the books and articles that Tony Bingelis wrote over the years sharing his VAST knowledge of great advice on how to build experimental homebuilt aircraft.________________________________________________________________________________Subject: Pietenpol-List: Re: split landing gear
