Pietenpol-List: MGL Electronic Tach
Posted: Thu Mar 10, 2011 10:20 am
Original Posted By: Gordon Bowen
Subject: Pietenpol-List: MGL Electronic Tach
Pietenpol-List: Re: KM Heide or Minnesota Corvair Engine?
Posted: Thu Mar 10, 2011 12:00 pm
I just happened upon Emory's web site and found a great read about Jeff. He isdoing some great work and is taking on more. Jeff be careful to leave time tofly the Pietenpol.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: KM Heide or Minnesota Corvair Engine?
Pietenpol-List: Re: Props and hub and progress
Posted: Thu Mar 10, 2011 12:35 pm
Original Posted By: "bender"
Thanks to all for the responses. Ken, I'll give you a call in the next day ortwo if that'd be okay. Now that the snow is starting to thaw (at least a littleanyway), we'll have to plan a visit so I can see your build. I'll also checkthe Corsa website for a local chapter. Kind of interested also in the GeorgiaCorvair engine given that if I used that nearly every part of my plane wouldhave come out of Georgia (my orders are delivered from the Peach Tree City,GA Aircraft Spruce). If I haven't any luck between now and Brodhead, I can followRyan's lead on my first trip there this July (I can hardly wait for thattrip!).Again, thanks to all.TomRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Props and hub and progress
Posted: Thu Mar 10, 2011 1:34 pm
i bought the plans years ago... simple plane to build and fly..nice to hear the piet fly like the speciali actually think a change in the airfoil on the special would be a good idea..it has the airfoil used on the later pitts...not flat on the bottom.... and itsnot that great for the special speeds. lots of guys had to change the angleof incidence i added about 2 degrees to both wings if i remember correctly toget it to fly more leveli actually soloed in that plane... it was way easy to landi may build another some day.. and maybe with a clark Y and a VWjeff faithRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Props and hub and progress
Posted: Thu Mar 10, 2011 1:44 pm
We considered the VW but we were flying it as an ultralight and didn't want toadd the weight. As it was, it was already heavy. It is now in the experimentalcategory since the light sport rules. I think this link will show you theplane. http://www.google.com/imgres?imgurl=htt ... -----Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 10 Mar 2011 13:52:38 -0600
