Pietenpol-List: carb question
Posted: Fri Mar 18, 2011 8:35 am
I have a glass Piet wing tank that I will sell cheep, It started to leak when thenew ,better fuel was forced upon the people. Went to Aluminum, no problems,when welded right.Pieti LowellRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: carb question
Posted: Fri Mar 18, 2011 8:39 am
Before I take carb off of engine,..I have an A65-8 w/Stromberg carb. I ran theengine yesterday (runs good), but the throttle cable works backward. Is therea way to rig the valve in said carb to work in the opposite direction?... my otheroption would be to tear fabric off side of aircraft in order to put a differentthrottle cable in...hate to do that. thx in advance..Read this topic online here:
Re: Pietenpol-List: carb question
Posted: Fri Mar 18, 2011 8:46 am
I don't know if it would be considered good practice or not, but is it possible to add linkage at the engine end of the throttle cable that would reverse the direction of travel at the carb?Kip GardnerOn Mar 18, 2011, at 9:39 AM, TriScout wrote:> >> Before I take carb off of engine,..I have an A65-8 w/Stromberg carb. > I ran the engine yesterday (runs good), but the throttle cable works > backward. Is there a way to rig the valve in said carb to work in > the opposite direction?... my other option would be to tear fabric > off side of aircraft in order to put a different throttle cable > in...hate to do that. thx in advance..>>> Read this topic online here:>>
Pietenpol-List: Re: carb question
Posted: Fri Mar 18, 2011 2:27 pm
Original Posted By: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]"
Can you rotate the carb 180 degrees? The lever would change sides and reverse operation.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:
Posted: Fri Mar 18, 2011 5:37 pm
I really don't know whether this would even be possible, but how about just turning the carb around 180 degrees -- that would make the throttle lever move to low power when you pull the lever back and to high power with the lever pushed forward. Would that work?----- Original Message -----
Re: Pietenpol-List: Jack makes a good point about.........
Posted: Fri Mar 18, 2011 5:55 pm
Original Posted By: Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]
I believe you'll find that Grace has a Taylorcraft. ----- Original Message -----
Posted: Fri Mar 18, 2011 8:52 pm
Gardiner I would love to go. I have been having health problems(heart) and I amgoing to stay close to home for a while. I sure would like to see your Piet again.Maybe Evergreen???--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: carb question
Posted: Fri Mar 18, 2011 8:58 pm
Original Posted By: airlion
I think I have a fix. The previous owner said to loosen screw on throttle arm (atcarb), pop it off and position it on top, then twist or bend as needed. I didjust that and it seems to work just fine...same travel each direction. Whowould've thought it was that simple. Thanks for your inputs.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 18 Mar 2011 19:14:05 -0700 (PDT)
