Re: Pietenpol-List: Storms damage Piets
Posted: Wed Mar 30, 2011 8:53 pm
Were praying for all our friends out at Sun n' Fun. We're seeing a lot of bad weather down here, reports of a tornado, damaged buildings and aircraft.http://www.theledger.com/apps/pbcs.dll/gallery?Dato 110331&Kategori=PHOTOS51&Lopenr=331009999&Ref=PH&pl=1Pictures;http://www.theledger.com/apps/pbcs.dll/gallery?Dato 110331&Kategori=PHOTOS51&Lopenr=331009999&Ref=PH&pl=1" target=_blank>http://www.matronics.com/Navigator?Piet ... ______Date: Thu, 31 Mar 2011 15:44:56 -0500Subject: Re: Pietenpol-List: Storms damage Piets
Pietenpol-List: Re: Storms damage Piets
Posted: Thu Mar 31, 2011 6:50 pm
Original Posted By: "gtche98"
Someone asked off list what was wrong with my heads. Here's a quick update: Iposted here a few months ago that I noticed a power drop last time I flew theplane. Brought her home successfully. Went through the troubleshooting stepsWilliam Wynne helped me develop. Bottom line - no compression in #3 cylinder.Pulled the heads and found the exhaust valve missing a chunk. Pulled the otherhead, too, based on differential compression numbers. I'm no expert, butI think I was about to trash a valve on that side as well - another exhaust valvewas looking rough. I sent the heads to get reworked at Roy's, one of William'srecommended shops. They're back and they look great. Roy said that theexhaust guides were shot and that the valve spring pressures were out of tolerance.He believes that the incorrect pressures (too low) prevented the valvesfrom closing tightly and dissipating heat the way they should, likely leadingto the burned valves.I had the heads done at a car shop many years ago, before the state of the artin head work had advanced to its current state. If all the recommended vendorsdo head work like Roy, we should be in pretty good shape.Next steps: install 5th bearing, reassemble motor, fly.--------Kevin "Axel" PurteeNX899KPAustin/Georgetown, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Storms damage Piets
Posted: Thu Mar 31, 2011 7:31 pm
Original Posted By: Stu Brown
That picture made me physically ill. Words can't express my sympathy. While outsidersmay see 3 damaged planes, I can only see the thousands of hours of blood,sweat and tears that were poured into those beautiful machines. The reportI saw from EAA was that there were no significant injuries at the site itself.I thank God for that and pray for the health and safety for everyone in thearea.--------Gary WilsonGreenville Wisconsingtche98 (at) gmail ((dot)) comPlanning PhaseRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 31 Mar 2011 21:16:45 -0400
>> To: >> Subject: Pietenpol-List: S2S, S4S, or what?>>>> >>>> Well, my plans are on order, I am pricing wood (a painful endeavor), and I >> have come up with a question. I live in the South, so it is not very easy >> to purchase wood here locally (unless you want to build your airplane with >> pine. Not happenin'). So, trying to be the scrounger and cost conscious >> builder, I am wondering the following->>>> 1. I am going to do the wing ribs first. A common place to start. Is it >> necessary to use S4S, can you get by with S2S, or can I purchase lumber >> and cut it to size myself? I am guessing the answer is that I need (at a >> minimum) S2S, otherwise I need to take rougher lumber and either plane it >> myself, or have someone do it for me so that the strips are all the same >> thickness.>>>> 2. Is there a reason for the capstrips to be finished on all four sides, >> or can I cut them on my table saw the correct width, then lightly sand >> them prior to varnishing them?>>>> My preference would be to ship larger pieces of spruce or fir, and then >> plane and cut them myself. If you are telling me I absolutely need S4S or >> S2S then that is what I will do.>>>> Thanks in advance for the advice. Probably it is a silly question, but I >> want to do things right. We used to say in the Marine Corps, "There is no >> such thing as a dumb question, although, there are some that come >> extremely close." This may be on of those close questions.>>>> -------->> Semper Fi,>>>> Terry>>>>>>>>>> Read this topic online here:>>>> http://forums.matronics.com/viewtopic.p ... 566#335566>>>>>>>>>>>>>>>>>>>>>>>> >>________________________________________________________________________________Date: Thu, 31 Mar 2011 14:02:56 -0600Subject: Pietenpol-List: Storms damage Piets
