Pietenpol-List: one man's leading and trailing edge ideas for Pietenpol
Posted: Wed May 25, 2011 9:32 am
Subject: Pietenpol-List: one man's leading and trailing edge ideas for Pietenpol [cid:image007.jpg(at)01CC1AC7.02046BC0] [cid:image008.png(at)01CC1AC7.02046BC0][cid:image009.jpg(at)01CC1AC7.02046BC0]________________________________________________________________________________Date: Wed, 25 May 2011 08:02:21 -0700 (PDT)
Pietenpol-List: Re: Ryan and Jack
Posted: Wed May 25, 2011 10:12 am
What a team!Knowing both of these gentlemen quite well, I have to comment on how out of characterthis is for both of them.... just kidding. :)I'm not really surprised at all.Nice move gents.BCRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Dihedral vs. crosswind
Posted: Wed May 25, 2011 10:17 am
Jack said it all, but I thought I would share this interesting picture Itook at Brodhead =9209. I believe it=92s the Piet Rob Bach was flying, and notsure he still has it..Rob Bach - 3, Dihedral.jpgNow=85that=92s some dihedral!!!GaryStill in Cool
Posted: Wed May 25, 2011 10:27 am
Original Posted By: airlion
Pietenpol-List: Re: one man's leading and trailing edge ideas for Pietenpol
Posted: Wed May 25, 2011 12:03 pm
Original Posted By: "Jack"
I used Mike's technique... fairly straightforward and I was able to achieve goodresults. Thanks Mike! I purchased two 14' long white pine handrails from Home Depot and ripped them asMike shows in his drawing.The bottom of the LE rounds our nicely with the bottom of the ribs.The top of the LE overlaps the top of the ribs ~1/16"... perfect for fitting LEsheeting.Here is something to think about... I had to install backing strips in order toprovide a surface to attach the LE sheet. I just used short lengths of 1/4"x 1/4" bass wood. Markle has a pretty good method for providing LE attachingsurface, but it requires a bit more work on the table saw.I also used a simple white pine base board and cut it the way Mike illustrates.This was pretty simple to do. I used wide tongue depressors for gussets...tapered on both ends. --------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
