Pietenpol-List: Colorado Pietenpols
Posted: Fri Jul 15, 2011 11:47 am
Hi,I didn't want to hijack the High Altitude Pietenpol thread and decided to startmy own.I currently live in the Chicago are and am considering starting a Pietenpol/Corvairproject.There is a possibility that within the next couple of years I will be moving toLongmont, Colorado.How well will the Pietenpol perform as a two place airplane flying in the Longmont,Colorado area?Thanks-Glenn--------This e-mail was written using 100% post-consumer recycled data. Please considerthe environment and recycle this data after use.Read this topic online here:
RE: Pietenpol-List: Colorado Pietenpols
Posted: Fri Jul 15, 2011 12:06 pm
The short answer is that it depends on the engine and the propeller.Longmont is not actually in the mountains, being about 20 miles east ofBoulder, as I recall. Still, field elevation there will be about 5,000'.If it were me, I'd put an O-200 Continental on it and stop worrying.Jack PhillipsNX899JP "Icarus Plummet"Smith Mountain Lake, Virginia-----Original Message-----
Re: Pietenpol-List: Colorado Pietenpols
Posted: Fri Jul 15, 2011 12:25 pm
Original Posted By: mark lee
Subject: Re: Pietenpol-List: Colorado Pietenpols
Posted: Fri Jul 15, 2011 12:29 pm
Subject: Re: Pietenpol-List: Colorado PietenpolsHi Glenn,As Jack said - depends on engine. I fly out of Front Range- on the plains near DIA. Figure starting at 5,500 at Longmont plus density altitude.Let me know if you are coming out - my Piet might even be done by then (but I wouldn't count on it). FYI - I'm doing a Corvair engine.CheersJon ApfelbaumIn a message dated 7/15/2011 11:10:05 A.M. Mountain Daylight Time, pietflyr(at)bellsouth.net writes:--> Pietenpol-List message posted by: "Jack Phillips" The short answer is that it depends on the engine and the propeller.Longmont is not actually in the mountains, being about 20 miles east ofBoulder, as I recall. Still, field elevation there will be about 5,000'.If it were me, I'd put an O-200 Continental on it and stop worrying.Jack PhillipsNX899JP "Icarus Plummet"Smith Mountain Lake, Virginia-----Original Message-----
Re: Pietenpol-List: Re: Colorado Pietenpols
Posted: Fri Jul 15, 2011 12:49 pm
Subject: Re: Pietenpol-List: Re: Colorado PietenpolsDrop me a line - I'll meet y'all for flying lies and cervesa!CheersJonIn a message dated 7/15/2011 11:40:20 A.M. Mountain Daylight Time, freerangequark(at)gmail.com writes:--> Pietenpol-List message posted by: "freerangequark" Jon,Will do! I may be out that way in August.-GlennDO NOT ARCHIVE[quote="Dog67(at)aol.com"]Hi Glenn,As Jack said - depends on engine. I fly out of Front Range- on the plains near DIA. Figure starting at 5,500 at Longmont plus density altitude.Let me know if you are coming out - my Piet might even be done by then (but I wouldn't count on it). FYI - I'm doing a Corvair engine.CheersJon ApfelbaumIn a message dated 7/15/2011 11:10:05 A.M. Mountain Daylight Time, pietflyr(at)bellsouth.net writes:> --> Pietenpol-List message posted by: "Jack Phillips" > > The short answer is that it depends on the engine and the propeller.> Longmont is not actually in the mountains, being about 20 miles eastof> Boulder, as I recall. Still, field elevation there will be about 5,000'.> If it were me, I'd put an O-200 Continental on it and stop worrying.> > Jack Phillips> NX899JP=EF=BD "Icarus Plummet"> Smith Mountain Lake, Virginia> > -----Original Message-----
Posted: Fri Jul 15, 2011 1:10 pm
Posted: Fri Jul 15, 2011 1:19 pm
Original Posted By: Jim Boyer
Posted: Fri Jul 15, 2011 4:07 pm
I knew I wasn't the only one who was bored on the Friday before Holy Week.--------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 15 Jul 2011 17:34:52 -0600Subject: Re: Pietenpol-List: Colorado Pietenpols
Posted: Fri Jul 15, 2011 7:25 pm
Posted: Fri Jul 15, 2011 10:30 pm
Posted: Sat Jul 16, 2011 6:13 am
As previously stated by Ken,I have an O 235 putting out 125 @sea level.At 78 F density altitude of 8000' I am off in 650-800' at 1175lbs.Can get up to14,000' on a cool morning.I wouldn't have a smaller engine on a bet unless youjust want to fly in the winter and fly east to cranksnappin country.dave--------taking to hangarRead this topic online here:
Posted: Sun Jul 17, 2011 12:52 pm
I ran the Riblett and the FC-10 airfoils through X-Foil airfoil simulation software. I really, really need to find the time to do a better analysis, but my preliminary findings are that the Riblett GA30-612 airfoil is a bit better than the FC-10 by about 10%. That is, it will climb about 10% faster, and glide about 10% farther than the FC-10. Other advantages - it's thicker so you can put a bigger center section fuel tank in there. It still looks like an FC-10 with the under camber. Disadvantages - it's not a pure Pietenpol design and you will garner the derision of the purists. The FC-10 is a fine airfoil, too. It cruises faster than a Cub's USA-35B. Dan-- Dan Yocumyocum137(at)gmail.com"I fly because it releases my mind from the tyranny of petty things."> ________________________________________________________________________________Date: Sun, 17 Jul 2011 11:17:35 -0700Subject: Re: Pietenpol-List: Re: Colorado Pietenpols
Posted: Sun Jul 17, 2011 2:10 pm
What? You want to land slower than 35mph? It's hard to beat 35mph. -- Dan Yocumyocum137(at)gmail.com"I fly because it releases my mind from the tyranny of petty things."On Jul 17, 2011, at 1:17 PM, mark lee wrote:> Glad you are looking into it.Is there any idea of how it will effect the stall speed?Looks like some major performance gains to me.I'm sure that Mr Pietenpol would have voted to keep the plane out of the rocks.He built what he needed and I think we will have to do the same.I can live with some derision as long as they can't follow me home.We are talking runways that are higher than some service ceilings.This isn't going to be easy.> > On Sun, Jul 17, 2011 at 10:52 AM, Dan Yocum wrote:> I ran the Riblett and the FC-10 airfoils through X-Foil airfoil simulation software. I really, really need to find the time to do a better analysis, but my preliminary findings are that the Riblett GA30-612 airfoil is a bit better than the FC-10 by about 10%. That is, it will climb about 10% faster, and glide about 10% farther than the FC-10. > > Other advantages - it's thicker so you can put a bigger center section fuel tank in there. It still looks like an FC-10 with the under camber. > > Disadvantages - it's not a pure Pietenpol design and you will garner the derision of the purists. > > The FC-10 is a fine airfoil, too. It cruises faster than a Cub's USA-35B. > > Dan> > -- > Dan Yocum> yocum137(at)gmail.com> "I fly because it releases my mind from the tyranny of petty things.">> > > > " target="_blank">
http://www.matronics.com/Navigator?Pietenpol-List> tp://forums.matronics.com> _blank">
http://www.matronics.com/contribution> > > > ============================================================================================================================================> ________________________________________________________________________________
Posted: Sun Jul 17, 2011 5:53 pm
Original Posted By: "Jack"
Gentlemen,This is a very interesting topic, especially since I am so new to the world ofPiet building. May I ask where you find all of these different airfoils and such?I wouldn't mind learning more about the Riblet, as it sounds like a more comfortableand viable option for long flights the wife and I will be partakingin... as I am sure we will have to hit high altitudes somewhere going from westcoast to east coast. Very respectfully,DerekRead this topic online here:
RE: Pietenpol-List: wi fi
Posted: Sun Jul 17, 2011 5:59 pm
Gardiner, look me up, I will have my Sprint Card.Jack,DSM-----Original Message-----
Posted: Sun Jul 17, 2011 6:09 pm
