Pietenpol-List: tail spring
Posted: Tue Sep 20, 2011 3:40 pm
Original Posted By: "bender"
I like the idea!!----------Randall02xB || !02xBRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: tail spring
Pietenpol-List: Re: Modified Seine Knot
Posted: Tue Sep 20, 2011 4:20 pm
Original Posted By: "dwilson"
OK.... so i had a leaf from a model a that i cut down and was using as a tail spring...dida little trimming and bending and ...pow.... broke iti know there are other options and i've seen them... but i like the leaf spring.the Ragwing Special i built had an aluminum spring... 1 1/2 - 1/2 inch thick 6061...bent in a pressi know grove made an aluminum spring for the kitfox.. anybody here ever use aluminum ??i'll be in Wichita next week and will have access to lots of metal..thought aboutdoing some shopping for some aluminum to try outany thoughts ??jeffRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Modified Seine Knot
Re: Pietenpol-List: tail spring
Posted: Tue Sep 20, 2011 5:34 pm
Original Posted By: BRETT PHILLIPS
I have just a little experience teaching others how to tie this knot. I believethat If you really want to learn how to do it you have to demonstrate the stepsto someone else. Then you will never forget ! Usually takes less than 10minutes unless of course your norwegian!DanThat might be a violation!Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 20 Sep 2011 18:43:26 -0400Subject: Re: Pietenpol-List: tail spring
Posted: Tue Sep 20, 2011 8:46 pm
Original Posted By: bender
Jeff,I believe Zenith 601's are now using 6061 gear legs. I know of at least one builderof the older HDS model that converted the straight, coil spring gear to bent6061. As I recall, he just bent the gear legs in a Harbor Freight press. Don'tsee why it wouldn't work for a tail spring.Gary------Original Message------
