Re: Pietenpol-List: members in the news
Posted: Mon Nov 28, 2011 8:48 am
Original Posted By: dog67(at)aol.com
We just use a simple little "shackle". Cable from cockpit goes beyond center section into wing. Then between root rib and next rib cable meets cable from the aileron. Connect there with the shackle and provide inspection hole below junction.Turnbuckle for tension adjustment is on lower aileron horn for easy access.Jeff Wilson St. Louis, MOSent from my iPhoneOn Nov 28, 2011, at 8:02 AM, Greg Bacon wrote:> Does anyone have close-up photos of a simple aileron cable quick disconnect or product info for an off-the-shelf item?> > =46rom westcoastpiet.com photos, I see Jack Phillips used disconnects, but I can't make out enough detail. I think Corky may have used them as well.> > For future reference, the purpose for the disconnects is to avoid having to disassemble the center section pulleys in the event wings are removed. > > Thanks.> > -- > Greg Bacon> Prairie Home, MO> > > > ===============================================================================================================================================================================> ________________________________________________________________________________Subject: Re: Pietenpol-List: members in the news
Posted: Mon Nov 28, 2011 9:50 am
Original Posted By: CozyGirrrl(at)aol.com
http://www.ourcoloradonews.com/castlero ... __________
