Re: Pietenpol-List: brass tipped prop
Posted: Fri Jan 27, 2012 7:47 pm
Original Posted By:=0A John Greenlee
=0AHi John,=0A=0A=0A-=0A=0A=0AI have posed this very question to the list previously, with few results. Some of the guys forwarded some helpful information, but it never really gets down to the difficult part, which is forming the brass to the exact shape of the prop in order to match it perfectly. Obviously this has been done countless times in the past, but I haven't been able to come up the secret.=0A=0A=0A-=0A=0A=0ADan Helsper=0A=0A=0APuryear, TN=0A=0A=0A=0A=0A=0A-----Original Message-----
Hi John,I have posed this very question to the list previously, with few results. Some of the guys forwarded some helpful information, but it never really gets down to the difficult part, which is forming the brass to the exact shape of the prop in order to match it perfectly. Obviously this has been done countless times in the past, but I haven't been able to come up the secret.Dan HelsperPuryear, TN-----Original Message-----
Posted: Sat Jan 28, 2012 12:28 am
Original Posted By:=0A airlion
=0AGardiner,=0A=0A=0A-=0A=0A=0AI am thoroughly confused. I flat out don't understand your question. Could you please re-state. Thanks.=0A=0A=0A-=0A=0A=0ADan Helsper=0A=0A=0APuryear, TN=0A=0A=0A=0A=0A=0A-----Original Message-----
Pietenpol-List: Re: rib jig
Posted: Sat Jan 28, 2012 6:13 am
I just took some plastic shopping bags and cut them into 2 inch squares and put a piece under each glue joint.- The plastic would pull right off of T-88 and made it real easy to get the rib out of the jig.- A few years ago at the Sun-N-Fun workshop someone made a rib in the jig without any protection under the glue joints, and I'm wondering if they ever got that rib out.BenOn 1/28/2012 11:55 AM, JOSEPH SWITHIN wrote: When you builders made your jigs for doing the ribs, did anyone drill holes at the glue spots so any excess would fall away? How many wet the two surfaces prior to applying glue? Last but not least, did anyone use the west system?-Joe SwithinMorris, IL-- Ben Charvet, PharmDStaff PharmacistParrish Medical center________________________________________________________________________________Subject: Pietenpol-List: Re: rib jig
Posted: Sat Jan 28, 2012 10:08 am
Hello,I carved a few props for the Model A several years ago. What I have neverfound is instructions on how to apply a brass leading edge. Has anyone heredone this? Do you have any instructions?Thanks!JMG________________________________________________________________________________Date: Sat, 28 Jan 2012 11:46:58 -0500
RE: Pietenpol-List: brass tipped prop
Posted: Sat Jan 28, 2012 11:09 am
JohnYou need to download this bookThe Airplane Propeller By United States. Army. Air Corps, United States. Adjutant-General's Officehttp://books.google.com/books?id=JndBAAAAIAAJ&dq=aircraft%20propeller%20manufacturing%20coppering&pg=PA7#v=onepage&q=aircraft%20propeller%20manufacturing%20coppering&f=falseThe information your looking for starts on page 107 of the PDF.ChrisSacramento, CaWestcoastpiet.com _____
Posted: Sat Jan 28, 2012 11:13 am
Re: Pietenpol-List: rib jig
Posted: Sat Jan 28, 2012 11:45 am
Original Posted By: JOSEPH SWITHIN
My rib jig was built using a 2 X 8 piece of lumber. Material was removed from the 2 X 8 at the glue joints. I used Aerolite adhesive applying resin on one surface and activator on the mating surface. If using T-88 or West it is good practice to apply adhesive to both mating surfaces.Greg CardinalMinneapolis ----- Original Message -----
Posted: Sat Jan 28, 2012 11:49 am
Posted: Sat Jan 28, 2012 12:00 pm
Joe, the disadvantage that I can see with a jig having holes at the joints is thatwhile excess epoxy will be able to fall away, not ALL of the excess will dripoff. You will likely end up with a small blob of hardened epoxy that you willneed to remove before attaching the gussets. By using a method like Ben described,any excess epoxy remains flat, making the attachment of gusset platesmuch easier. On the other hand, you really don't need that much epoxy. If you'rea tidy builder, there really shouldn't be much excess glue.For epoxy, I used T-88, which is very simple to mix; 1:1 by volume - no ratiosto calculate, no need for weigh scales. Some people have expressed a preferencefor the West System, but I don't know what the preference is based on. I likesimple, and a one to one mixing ratio is as simple as it can get (for a two-partepoxy).Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 28 Jan 2012 11:01:29 -0700Subject: Re: Pietenpol-List: rib jig
Posted: Sat Jan 28, 2012 12:47 pm
Posted: Sat Jan 28, 2012 1:03 pm
4 mil visqueen right over the rib drawing. After 3 years, and 100's of ribs(seemed like it), it's still good. But, the BEST NEWS is.sounds like you'rebuilding an airplane!!Gary BootheNX308MB
Posted: Sat Jan 28, 2012 1:04 pm
Joe see here http://www.textors.com/RibJig.jpg I use west system for areas where I need a large batch of glue, not for the ribsjackDesmondSent from my iPadOn Jan 28, 2012, at 10:55 AM, JOSEPH SWITHIN wrote:> When you builders made your jigs for doing the ribs, did anyone drill holes at the glue spots so any excess would fall away? How many wet the two surfaces prior to applying glue? Last but not least, did anyone use the west system? > > Joe Swithin> Morris, IL> > > ============================================================================================================================================> ________________________________________________________________________________
Posted: Sat Jan 28, 2012 1:19 pm
Original Posted By: airlion
Posted: Sat Jan 28, 2012 2:22 pm
Ladies and Gents. I have sold my piet and now have a full set of plans less a full size rib for sale.It is everything that you would get for the pietenpol family. They are lightly used. If you are interested I am asking 150.00 and I can fedexthem out tonight.I use paypal and can complete the transaction anytime.BillRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: brass tipped prop
Posted: Sat Jan 28, 2012 5:28 pm
Gardiner,I am thoroughly confused. I flat out don't understand your question. Could you please re-state. Thanks.Dan HelsperPuryear, TN-----Original Message-----
Posted: Sat Jan 28, 2012 5:53 pm
=0A Pietenpol-List: brass tipped prop
Posted: Sat Jan 28, 2012 11:35 pm
>> I just took some plastic shopping bags and cut them into 2 inch squares> and put a piece under each glue joint. The plastic would pull right off of> T-88 and made it real easy to get the rib out of the jig. A few years ago> at the Sun-N-Fun workshop someone made a rib in the jig without any> protection under the glue joints, and I'm wondering if they ever got that> rib out.>> Ben> On 1/28/2012 11:55 AM, JOSEPH SWITHIN wrote:>> When you builders made your jigs for doing the ribs, did anyone drill> holes at the glue spots so any excess would fall away? How many wet the two> surfaces prior to applying glue? Last but not least, did anyone use the> west system?>> Joe Swithin> Morris, IL>> *>> *>>> --> Ben Charvet, PharmD> Staff Pharmacist> Parrish Medical center>> *>> " rel=nofollow target=_blank>http://www.matronics.com/Navigator?Pietenpol-List> et=_blank>http://forums.matronics.com> llow target=_blank>http://www.matronics.com/contribution> *>> *>> *>>________________________________________________________________________________Subject: Re: Pietenpol-List: brass tipped prop
=0A Re: Pietenpol-List: brass tipped prop
=0A=0A=0A=0A=0A=0AHi John,=0A=0A=0A-=0A=0A=0AI have posed this very question to the list previously, with few results. Some of the guys forwarded some helpful information, but it never really gets down to the difficult part, which is forming the brass to the exact shape of the prop in order to match it perfectly. Obviously this has been done countless times in the past, but I haven't been able to come up the secret.=0A=0A=0A-=0A=0A=0ADan Helsper=0A=0A=0APuryear, TN=0A=0A=0A=0A=0A=0A-----Original Message-----
