Pietenpol-List: Galvanic Corrosion
Posted: Sun Jan 29, 2012 2:50 am
Original Posted By:=0A=0A=0A=0A=0Aowner-pietenpol-list-server(at)matronics.com=0A[mailto:own
=0A=0A=0A =0A =0A=0A =0A=0A =0A=0A =0A=0A=0A=0A=0A=0A=0A=0A=0A=0AAll right, Dan.=C2- Now you=99ve=0Adone it and inspired my Geekiness to come to the surface.=C2- Let=99s=0Atalk a bit about Galvanic Corrosion.=C2- This occurs when you have dissimilar=0Ametals in intimate contact in an environment where they can get wet, such as at=0Athe ends of lift struts.=C2- Not all dissimilar metals cause problems =93=0Ait depends on how =9CAnodic=9D they are.=C2- There is a chart listing=0Athe Anodic Index of all common metals.=C2- To find the susceptibility to=0Acorrosion of any metal pair, find the difference in their anodic indices =93=0Athe corrosion will take place at the more anodic of the pair (this is why on=0Aoutboard motors that may be run in saltwater you will find =9Csacrificial=0Aanodes=9D of magnesium or zinc on the aluminum casings of the motor, so the=0Acorrosion takes place there rather than on the aluminum. =0A=0A =C2- =0A=0AThe rule of thumb to be safe from galvanic=0Acorrosion is to have a difference in anodic index of no more than about 0.15 - 0.20=0Afor an outdoor environment.=C2- Here is the chart: =0A=0A =C2- =0A=0AMetal Category=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- Anodic=0AIndex (volts) =0A=0A =C2- =0A=0AGold, solid and plated=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.00 =0A=0ARhodium plated on Silver-plated Copper=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.05 =0A=0ASilver, high Nickel-Copper alloys=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.15 =0A=0ANickel, Titanium, Monel=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.30 =0A=0ACopper, Silver Solder, high Copper-Nickel=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.35 =0A=0Aalloys, Nickel-Chromium alloys =0A=0ABrasses & Bronzes=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.40 =0A=0A18% Chromium Stainless Steel=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.50 =0A=0AChromium plating, Tin plating=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.60 =0A=0ATin-Lead solder=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.65 =0A=0ALead=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.70 =0A=0AAluminum, wrought, 2000 series=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.75 =0A=0AIron, plain carbon or low-alloy steel=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.85 =0A=0AAluminum, wrought alloys other than 2000=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.90 =0A=0Aseries (such as 7075) =0A=0ACast Aluminum alloys, Cadmium plating=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 0.95 =0A=0Aand Chromates =0A=0AHot-dip Zinc, galvanized steel=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 1.20 =0A=0AZinc=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 1.25 =0A=0AMagnesium=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 1.75 =0A=0ABeryllium=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 1.85 =0A=0A =C2- =0A=0AOne of the important things to notice is=0Athat cad-plated steel (such as AN aircraft hardware) is not too bad when placed=0Aagainst 2024 series aluminum, and is even better against 7075 series.=C2-=0AWhat is surprising to most people is how bad stainless steel is against=0Aaluminum (difference of .40 to .50). =0A=0A =C2- =0A=0AHope this helps.=C2- By the way, I=0Achanged the subject to hopefully make this chart easier to locate in the=0Aarchives =0A=0A =C2- =0A=0AJack Phillips =0A=0ANX899JP =0A=0ASmith Mountain Lake, Virginia =0A=0A =C2- =0A=0A=0A=0A=0A=0A
