Pietenpol-List: Horizontal StabilizerAttachment
Posted: Tue Feb 14, 2012 12:16 am
Original Posted By: "Jack"
When installing the horizontal stabilizer there are two fittings on the rearand beneath the stabilizer. Two bolts are to pass through one fitting,through the fuselage and through the second fitting. Problem is thefuselage sides are not parallel in this area. I'm trying to figure out thebest way to run the bolts through the two fittings. Do I add wood shims sothe fittings lay flat or do I make wedge shaped washers for under the bolts?Other suggestions?ChrisSacramento, CaWestcoastpiet.com________________________________________________________________________________
RE: Pietenpol-List: Horizontal StabilizerAttachment
Posted: Tue Feb 14, 2012 5:51 am
Chris I used shims. When making the brackets pay attention to clearances, Iremade a few times! See here http://textors.com/DSCN4190_800x600.jpg Jack TextorDSMNX1929T-----Original Message-----
Posted: Tue Feb 14, 2012 6:24 am
I made wedge shaped washers for mine.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Posted: Tue Feb 14, 2012 6:50 am
Original Posted By: archive > catdesigns(at)att.net
I don't think it really matters=2C the bolts are in shear=2C there is no real reason that they can't be angled. Having said that=2C the amount it takes to make the fuselage sides parallel is only the thickness of the plywood doubler. I trimmed the plywood=2C so that the sides were parallel=2C in the area under the fittings. BYW=2C my plans show rivets there=2C not bolts. I used rivets=2C and with rivets it really does not matter if the sides are parallel. I chose to trim the plywood because with the fittings on an angle=2C it moved the bolt holes for the stabilizer aft a bit and made them not line up with the holes in the fitting on the vertical fin. Gene do not
Posted: Tue Feb 14, 2012 6:51 am
Should have used some sort of shims on mine, but sadly, did not. One of the small regrets and costs of "get-done-itis". A lesson for all who are still building. The parts that you rush will always be there to stare you in the face when you are done. It looks a little "off" but It'll never give way I'm sure. Dan HelsperPuryear, TN-----Original Message-----
Re: Pietenpol-List: Horizontal StabilizerAttachment
Posted: Tue Feb 14, 2012 8:56 am
Original Posted By: "Chris"
Chris, I also used shims. I made some shims out of spruce and when I got them to where the surfaces were parallel and glued the shims to the fuselage sides. Chuck----- Original Message -----
Posted: Tue Feb 14, 2012 9:14 am
#2 Chris, I also noticed on the plans in his book that Bernie calls for rivets rather than bolts on the top side of the stabilizer where the stabilizer is fastened to the vertical fin. I wondered why until I put everything together and found that the nuts on the bolts interfere with the vertical bolts going down through the fitting to the fitting on the lower side of the stabilizer. When I put the plane together for the inspection I'll use hardware store bolts and thin nuts and for the final time after covering, I'm going to use 3/16-inch rivets. C----- Original Message -----
Pietenpol-List: Re: Horizontal StabilizerAttachment
Posted: Tue Feb 14, 2012 11:25 am
Original Posted By: Jim Boyer
I know it's in the plans, and I know it's been done successfully in the past, andI know that's the way BHP did it... but using rivets in wood just doesn't giveme a warm, fuzzy feeling.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 14 Feb 2012 18:49:27 +0000 (UTC)
Posted: Tue Feb 14, 2012 12:56 pm
Re: Pietenpol-List: Re: Making Spars
Posted: Tue Feb 14, 2012 1:09 pm
Isn't there a window pane of knowledge a philosopher came up with? What we knowWhat we know we dont know andWhat we don't know we don't knowOr maybe I'm just working to hard today...Sent from my iPhoneOn Feb 14, 2012, at 9:31 AM, Michael Perez wrote:> Bill, Unknown Knowledge is like Unknown Unknowns. (It's a NASA thing)> > But judging from your last post, you are getting the idea.> > Michael Perez> Karetaker Aero> www.karetakeraero.com> > > > ________________________________________________________________________________Date: Tue, 14 Feb 2012 13:11:08 -0600
Posted: Tue Feb 14, 2012 1:23 pm
Posted: Tue Feb 14, 2012 2:40 pm
Original Posted By: Hans Van Der Voort
Hi Mike,Looks like someone did a field top overhaul on it. I can see that the cylindersare the old style with the bronze spark plug inserts and it also appears tohave possible cracks that run from the spark plugs to the exhaust seats. Youcan see there is one from each spark plug hole. They could be serviceable. Itwould be worth having them inspected by a shop. Something you could do yourselfis to put some spark plugs in the cylinders and pour some kerosene in them.If the cracks are big or the valves are not seated good you will see the leaks.Keep in mind that these little Cont engines will just keep running andrunning. Not everything needs to be brand new in them. There are serviceablelimits in the overhaul manual. As long as your parts meet those, consider themgood.BTW, My cylinders are also .015 over. Regards,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Horizontal StabilizerAttachment
> > > When installing the horizontal stabilizer there are two fittings on the rear> and beneath the stabilizer. Two bolts are to pass through one fitting=2C> through the fuselage and through the second fitting. Problem is the> fuselage sides are not parallel in this area. I'm trying to figure out the> best way to run the bolts through the two fittings. Do I add wood shims so> the fittings lay flat or do I make wedge shaped washers for under the bolts?> Other suggestions?> > Chris> Sacramento=2C Ca> Westcoastpiet.com> > > ============================================> > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Horizontal StabilizerAttachment
