Pietenpol-List: Continental engine cooling eyebrow drawings--inexpensive!
Posted: Fri Feb 24, 2012 1:56 pm
Subject: Pietenpol-List: Continental engine cooling eyebrow drawings--inexpensive!Stumbled upon this at the Cub Club web site. This is a deal. This is for DRAWINGS....not the actual partsto make the cooling eyebrows.https://www.cub-club.com/blueprint/Blue ... .10.pdfSee page 3.[cid:image001.png(at)01CCF304.8B617320]________________________________________________________________________________
RE: Pietenpol-List: Engine Push Rod Length
Posted: Fri Feb 24, 2012 2:15 pm
Michael, that expensive overhaul manual you bought should have a Table ofLimits in it. You'll find the information you need there.>From looking at mine, I find that the pushrods (new) should have a length of10.797" to 10.827". The serviceable limit length is 10.785"To determine if you need the oversize pushrods, you will have to have theengine assembled, and measure the clearance between the valve stem and therocker arm, with the hydraulic lifter fully deflated. The clearance issupposed to be between 0.030" and 0.110". If your clearance is more than0.110" you will need the longer pushrod.Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Re: Pietenpol-List: Continental engine cooling eyebrow drawings--inexpensive!
Posted: Thu Mar 01, 2012 7:13 pm
Original Posted By: "Jack(at)textors.com"
Hello good Piet-ple...A week ago I had Mike from "Ready Weld" come by for another all-day welding marathon.He worked on the pilot and passenger control sticks, the passenger door(heaven forbid!!), the tabs where the wood floor will bolt to the fuselage frame,and the attach fittings for the seat belts & shoulder harnesses. I have attached (hopefully) an image of the fuselage with the tabs jigged in place,a picture of the door in the wooden jig, Mike welding away, and a coupleof the fuselage which is now further along. Put it together, jig, take it apart, put it back together, take it back apart...repeat until finished (ha!) Lotsa funnn...!!--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/4_pi ... ___Subject: Re: Pietenpol-List: Continental engine cooling eyebrow drawings--inexpensive!
Posted: Fri Mar 02, 2012 8:49 am
Original Posted By: "Dick N"
Just a heads up. You must be a member to order the plans...Jack TextorSent from my iPadOn Feb 24, 2012, at 1:56 PM, "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" wrote:> Stumbled upon this at the Cub Club web site. This is a deal. This is for DRAWINGS.not the actual parts> to make the cooling eyebrows. > > https://www.cub-club.com/blueprint/Blue ... ing.10.pdf> > See page 3. > > > > > ________________________________________________________________________________
Pietenpol-List: Re: Interview with Kevin Purtee
Posted: Fri Mar 02, 2012 10:10 pm
My new issue of Sport Aviation came today. There is a great pic of Matt and his Piet. Good job Matt, pic is great.Dick N.________________________________________________________________________________Subject: Pietenpol-List: Re: Interview with Kevin Purtee
Posted: Sat Mar 03, 2012 9:35 am
Original Posted By: "Bob edson"
Now that is class- can't add anything more but it is good to know such capableand honorable folks still serve every day. RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
