Pietenpol-List: Carb Rebuild?
Posted: Thu Mar 22, 2012 11:57 pm
Original Posted By: Andrew Eldredge
Wow, how perfect! Did you make one for the VHF aircraft band? How'd the otherantennas work compared to ones on the ground? Have you tried a dipole for 2meter work airborne? Inquiring minds...!ToolsRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 22 Mar 2012 23:09:21 -0600Subject: Pietenpol-List: Carb Rebuild?
Pietenpol-List: Re: Carb Rebuild?
Posted: Fri Mar 23, 2012 8:54 am
Subject: Pietenpol-List: simple VHF antenna solution[cid:image004.jpg(at)01CD08DA.E53C00E0] I know nothing about aircraft antennas besides that this one works really well and itfits nicely inside my fuselage arched and secured in an upside down U-shape behind my rear seat area with nylontye wraps. I bought a coax cable with two female connectors-one connects to the antenna, the other to myIcom handheld radio.Mike C.
http://www.advancedaircraft.com/[cid:image003.png(at)01CD08DA.E430F980]________________________________________________________________________________Subject: Pietenpol-List: Re: Carb Rebuild?
Re: Pietenpol-List: Re: Carb Rebuild?
Posted: Sat Mar 24, 2012 2:53 pm
Subject: Re: Pietenpol-List: Re: Carb Rebuild?
Posted: Mon Mar 26, 2012 10:05 am
71x46 fits Continental A & C series and O-200. $500. (865)963-6978 pictures available.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Carb Rebuild?
Posted: Mon Mar 26, 2012 11:05 pm
Very good Andrew. I have needed to do that on several occasions with engines thathave sat around awhile. Glad it worked for you.Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:
