Pietenpol-List: Wings On!
Posted: Thu Apr 12, 2012 3:23 am
Original Posted By: "cjborsuk"
Subject: Re: Pietenpol-List: Re: Marvel mystery oil> > One also has to remember that there are rules in chemistry that dictate mixingorder of substances. First comes safety add acid to water > not water to acid. It's called reactivity, additionally the order > in which chemicals are combined my adversely impact the resultant > mixture and instead of a dispersion you end up with rocks. > > For the desired result one must follow the mix sequence as in a > specific recipe. It is entirely possible for a substance to congeal > if it is not mixed properly or in the proper order. Unless you're > mixing tap water with tap water. > > We all being people of science would prefer to debate anecdotal > information forever rather than to conduct simple scientific > research (a lab )and acquire exact information that accepts the > notion or refutes it once and for all! > > Ahhhhh yes sweet resolution learning the answer is not quite as > much fun as beating the issue to death and allowing it to come up > again in 6 or so months for another endless round of debate> > John> > > > Sent from my iPhone> > On Apr 12, 2012, at 8:13 AM, "womenfly2" > > > > First one has to think about the product and the company. Would they sell aproduct that would congeal in fuel as stated above? Not really, I would thinkif they did the company would have closed a long time ago. MMO is simply justa naphtha based solvent. Therefore mixes well with gasoline. > > > > Second, MMO is high in detergents and do a good cleaning job, possibility thatproblems people have maybe do to the suspension of the dissolved solids inthe gas which can lead to clog fuel filters and strainers making one think itsthe MMO product itself.> > > > Many pilots and mechanics use it, even at the field where I fly, from a DC3to all the flight training Cubs. One has ever had any issues with MMO.> > > > .... old wives's tale and hanger talk, defiantly.> > > > JMHO> > > > --------> > > > > > > > > > > > > > Read this topic online here:> > > > http://forums.matronics.com/viewtopic.p ... 595#370595> > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Wings On!
