> Pietenpol-List: Tailwheel endorsement
Posted: Wed May 23, 2012 9:16 am
Original Posted By: "Dick N"
Subject: Re: Pietenpol-List: Tailwheel endorsementScott, I'm in the US...Thanks,JF-----Original Message----->From: Scott Knowlton >Sent: May 23, 2012 7:46 AM>To: John Franklin , "pietenpol-list(at)matronics.com " >Subject: Re: Pietenpol-List: Tailwheel endorsement>>>John, Are you located in Canada or the USA? >>-----Original Message----->From: John Franklin >Date: Wed, 23 May 2012 12:00:55 >To: >Subject: Pietenpol-List: Tailwheel endorsement>>>Pieters,>>In order to obtain a tailwheel endorsement, do you have to log some minimum numberof hours in a taildragger or do you just need to be able to demonstrate capabilityto an examiner before he signs you off?>>Thanks,>John Franklin>Prairie Aire 4TA0>GN-1 / Corvair>>________________________________________>>________________________________________________________________________________________________________________________
Pietenpol-List: FAA's word on tailwheel endorsements and grandfather clause
Posted: Wed May 23, 2012 9:51 am
Original Posted By: "Scott Knowlton "
Subject: Pietenpol-List: FAA's word on tailwheel endorsements and grandfather 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________________________________________________________________________________
Posted: Wed May 23, 2012 10:14 am
Subject: Re: Pietenpol-List: Tailwheel endorsementHa! I liked your first answer better. I do Tailwheel conversions here in therepublic of Canada. It isn't a rating here... Just a proficiency check and usuallyonly for insurance purposes. I'm sure other folks on the list from theUS can answer your question. Regards,Scott -----Original Message-----
Re: Pietenpol-List: NX53WE--WE'RE TOGETHER AGAIN
Posted: Wed May 23, 2012 2:54 pm
Original Posted By: Bob edson
Beautiful Piet Bob , I was a bit distracted by the canoe hanging on the wall. Did you build that also? Thats a piece of art.Dick N. ----- Original Message -----
Re: Pietenpol-List: cable cutting
Posted: Wed May 23, 2012 6:46 pm
I could use some helpful hints on cutting control cables and being able to insert them into splicing sleeves. I checked my blood twice getting one done today. There has got to be a better way.Ralph in South Dakota________________________________________________________________________________Date: Wed, 23 May 2012 17:57:24 -0600Subject: Re: Pietenpol-List: cable cutting
Posted: Wed May 23, 2012 7:02 pm
Posted: Wed May 23, 2012 7:24 pm
Pietenpol-List: Re: cable cutting
Posted: Wed May 23, 2012 7:26 pm
What worked best for me was to sharpen a chisel on my grinding wheel. I then placedthe cable of a piece of flat steel and sheared it with the chisel and ahammer. Nice clean cut but you will have to sharpen the chisel after abouttwo cuts. I believe this was in the the Tony Bingeles books.--------John FrancisRead this topic online here:
RE: Pietenpol-List: cable cutting
Posted: Wed May 23, 2012 7:52 pm
I just wrapped the area of the cut with masking tape then cut it with a coldchisel, a hammer and an anvil. I used a cheap harbor freight anvil becausethe chisel will cut into the anvil and ruin a proper anvil, so I bought asmall one that is used for nothing but cutting cable.Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Posted: Thu May 24, 2012 5:26 am
If you wrap with only one tight wrap of masking tape then cut, you can usuallyget the end of the cable through the sleeve with the masking tape still on there.Makes for a much happier time.Don EmchNX899DERead this topic online here:
Posted: Thu May 24, 2012 5:28 am
Original Posted By: Ralph
The absolutely best way is to cut the cable with a small Dremel tool with a cutoff wheel. I wrap the cable with a couple of layers of masking tape to keep the cable ends from fraying. If you're cutting after the sleeve is installed and crimped, use a thin piece of stainless steel between the cables to prevent nicking the opposite cable. Leeve at least 1/8-inch beyond the sleeve. C ----- Original Message -----
