Pietenpol-List: Brodhead Report - Late
Posted: Thu Aug 23, 2012 9:53 am
Thanks for the info Steve. Does it have a clamp, like a timing light?Greg BaconGarratt Callahangbacon@g-c.com(573)489-4795On Aug 23, 2012, at 9:34 AM, steve(at)wotelectronics.com wrote:> For my A-75 I use a Westach tachometer that just monitors the mag wires for RPM. This eliminates the need for a cable to the engine. Better accuracy and less maintenance. No bouncing, no lubing of cables, etc.> > I believe this is the model I use, check their documentation to make sure this is the correct model:> > > > > > > > > > http://www.aircraftspruce.com/catalog/i ... r3at32.php> > > > Steve Ruse> Norman, OK> > On 2012-08-23 08:40, Michael Perez wrote:> >> I do not have my tach. in hand at the moment, but I can get you the part number, (ACS), if you like. I am also using the 90 deg. adapter from ACS, so the rotation can be switched AND it makes running the tach cable easier in the small instrument compartment. (My opinion.)>> >> Let me know.>> >> Michael Perez>> Pietenpol HINT Videos>> Karetaker Aero>> www.karetakeraero.com>> http://www.matronics.com/Navigator?Pietenpol-List-> http://forums.matronics.com> > > > > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: Brodhead Report - Late
