Pietenpol-List: New Fabric
Posted: Thu Aug 30, 2012 9:14 am
Re: Pietenpol-List: New Fabric
Posted: Thu Aug 30, 2012 9:55 am
Original Posted By: Hans van der Voort
Subject: Re: Pietenpol-List: New FabricHans, do you have a web site for Oracover?In a message dated 8/30/2012 9:47:45 A.M. Eastern Daylight Time, nx15kv(at)yahoo.com writes:_http://
www.oracover.de/index.php/katalog/artik ... _1_m.html_ (
http://www.oracover.de/index.php/katalo ... t_1_m.html) I noticed Oracover now has fabric for full size aircraft (at least Pietenpol size)No dope, silver or finsh color required, just glue on shrink and done.Just like a model airplane.The model airplane market must be drying up for them, to start marketing to the experimental market.Who wants to be the first to try this ?FYI, I do not endorse this in anyway, just thought the information is interesting.HansNX15KV(
http://www.matronics.com/Navigator?Pietenpol-List) (
http://www.matronics.com/contribution) ________________________________________________________________________________Date: Thu, 30 Aug 2012 13:33:30 -0700 (PDT)
Re: Pietenpol-List: Aileron Capstrip
Posted: Thu Aug 30, 2012 4:20 pm
I ran my hinge all the way up so that the "knuckle" was even with the top of the capstrip. I did all this after the aileron was cut away from the wing. Yes, the filler capstrip was shaped so that the hinge would lie flat. The filler capstrip was moved forward so that the top-forward edge was even with the front of the sloped side of the aileron spar. Clear as mud? C----- Original Message -----
Pietenpol-List: Re: Straight Exhaust
Posted: Thu Aug 30, 2012 5:54 pm
Mike:I use scrap SS 1-1/2" OD that is used for milking machines, it is available inall lengths and 90 Degree bends that can be cut and welded to any angle required.There is piles of this type of Stainless West of Hartford Airport Wisconsin,If interested when you are ready and I will get the fellow pilot's name andcontact info for you,Pieti LowellRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 30 Aug 2012 16:01:46 -0700 (PDT)
Re: Pietenpol-List: Re: Straight Exhaust
Posted: Thu Aug 30, 2012 6:26 pm
Re: Pietenpol-List: Full Tail Wheel Disclosure! (Almost...)
Posted: Thu Aug 30, 2012 8:57 pm
Original Posted By: Andrew Eldredge
Subject: Re: Pietenpol-List: Full Tail Wheel Disclosure! (Almost...)
Posted: Fri Aug 31, 2012 4:11 am
You are correct Andrew, as the spring compresses and the A arm swings towards the fuselage, the angle on the bolt tubes changes.- I was able to construct mine to minimize the binding at these locations.- It is only at the extreme end of travel, where the spring is almost fully compressed, that there is any sign of binding.- In my mind, it is not going to be an issue, considering how often the gear gets compressed to that extreme.Michael PerezPietenpol HINT VideosKaretaker Aerowww.karetakeraero.com________________________________________________________________________________
You are correct Andrew, as the spring compresses and the A arm swings towards the fuselage, the angle on the bolt tubes changes. I was able to construct mine to minimize the binding at these locations. It is only at the extreme end of travel, where the spring is almost fully compressed, that there is any sign of binding. In my mind, it is not going to be an issue, considering how often the gear gets compressed to that extreme. Michael Perez Pietenpol HINT Videos Karetaker Aero
www.karetakeraero.com" rel=nofollow target=_blank>
http://www.matronics.com/Navigator?Piet ... cs.comllow target=_blank>
http://www.matronics.com/contribution__ ... ___Subject: Pietenpol-List: Re: Straight Exhaust
Posted: Fri Aug 31, 2012 8:11 am
Posted: Fri Aug 31, 2012 7:50 pm
Posted: Fri Aug 31, 2012 8:24 pm
On NX18235 we installed rod end bearings at the A-arm ends.No binding and no wear.Greg Cardinal ----- Original Message -----
Posted: Sat Sep 01, 2012 10:59 am
The contact that I have for SS .Joel GehringCell : 262-224-5316Email:Ask for Joel He will also be at Brodhead this next week-end , Sept.7-9,@ MAAC Fly-In.Pieti LowellRead this topic online here:
