Re: Pietenpol-List: How to remove Latex paint from fabric
Posted: Thu Sep 13, 2012 10:43 pm
Original Posted By:----- Original Message ----- "giacummo"
Try normal paint stripper from the hardware store.- That will take it off just fine.- Scrape the residue off with a sharp plastic scraper then wash the remaining residue off.Dick N.
Posted: Fri Sep 14, 2012 10:48 am
They also build them in pa and have nice airports with plenty of tie down space Juss sayinSent from my iPhoneOn Sep 14, 2012, at 10:08 AM, woodflier(at)aol.com wrote:> Beautiful job, Jeff. With all the Piets now in KY, VA, NC, WV and MD, we ought to have a mid-Atlantic Piet get together to terrorize the spam cans! I look forward to seeing your airplane in person and flying.> > Matt Paxton> NX629ML> > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: How to remove Latex paint from fabric
Posted: Fri Sep 14, 2012 11:22 am
Before anything else, Jeff: congratulation for the Piet!!!, for me, here far awayfrom all those hand made flaying machines, its a .... pleasure?/confort?..I do not know how to said it.. see came out one after anoher with success.Now my little add..Few months ago I ask how to make certain repair in the rudder.. I install a wronghorn on it, cover the rudder, and paint it with latex to learn, and see howlatex work, later I discover the mistake... and the best answer I had was "cut,replace it and learn how to do it"... OK, I am in the process.. I do not care to cut, and replace it, the problem forme was the paint. How can I go to the fabric without damage it with the sandpaper?... I do not like that idea.. but if there is no other?.. I ask in painthouses if there is anything to remove the paint chemicaly.. the answer was nothing,so sand?.. so today I was in the garage doing others things and I sawa bottle of Tolueno that I use to clean the brushes I use to apply contac cement.and I try with it.. incredibel.. look this pictures herehttp://vgmk1.blogspot.com/2012/09/como-arreglar-un-agujero-y-rejadura-en.htmlthe fabric is like new.. without traces of the paint... So, if you are working with latex paint remember, tolueno (in english may be TOLUEN?)Regards--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 14 Sep 2012 11:48:25 -0500 (GMT-05:00)
Posted: Fri Sep 14, 2012 2:43 pm
Try normal paint stripper from the hardware store. That will take it off just fine. Scrape the residue off with a sharp plastic scraper then wash the remaining residue off.Dick N.----- Original Message -----
Posted: Fri Sep 14, 2012 3:17 pm
Original Posted By:> ----- Original Message ----- "giacummo"
Subject: Re: Pietenpol-List: How to remove Latex paint from fabricno, no, no ... Toluene is THE BEST, I discover it first.. ;o)))Mario Giacummo. -..- .. ... - .. .-. / . ... / ..- -. / .... . -.-. .... --- --..-- /...- .. ...- .. .-. / . ... / ..- -. / .- .-. - .not archive2012/9/14 Dick N >> Try normal paint stripper from the hardware store. That will take it off> just fine. Scrape the residue off with a sharp plastic scraper then wash> the remaining residue off.> Dick N.
