Pietenpol-List: wing length
Posted: Fri Oct 26, 2012 7:58 am
If I was starting over, I'd lengthen the wings in some fashion, either awider center section or slightly longer wing panels.Mainly because I've seen a couple fly like that and they perform markedlybetter on hot days with passengers.However, I must say that "RE-PIET" flies just fine with standard wings, andshe's heavy. However, there's a big motor up there swinging a bit prop. One interesting observation flying a fairly heavy Piet is that she reallyhandles the crosswinds nicely.Douwe________________________________________________________________________________
Re: Pietenpol-List: RE-PIET flying characteristics
Posted: Fri Oct 26, 2012 8:23 am
Okay good people.Have flown RE-PIET now for five hours and thought I'd make an early pilotreport.My darn GPS wouldn't turn on the first non-wind day I had, which was the dayI had planned to get some accurate speeds.gotta love electronics. I have awind vane airspeed indicator which isn't super accurate so I need somethingextra.She SEEMS to cruise at 70 at 2300.My favorite cruise condition is 2000, indicating around 60. Nice and quietand she'll still climb, though slowly.Power off stalls are nice and gentle. Have no idea of the speed, the windvane indicator reads zero.Power on stall is more like a mushing descent, it's hard to get a realbreak. She just hangs there like a Fokker D-7 with her nose in the air.She turns on a dime!After reading all the landing advice and watching hundres of landings overthe last decade, I was prepared for a rather pronounced sink rate once I cutthe engine. So the first few landings, I cut it closer than with the cubjust to be prepared for the steep descent. and each time found myselffloating across the runway longer than the cub! This is on 75 degree dayson grass. She seems to float more than the cub I was flying, strange. Ican't explain it because she's heavy, but maybe the wing axle fairing ishelping a bit? Or the large airfoil wing tank? Who knows.So far she lands easier than the Cub, as it's really easy to decide when tostop her flying and because of that, you actually have more control of whenthings happen. She lands very easily. Yesterday was a no wind day and Iwas set up on final, coming right down at my aiming point and doingabsolutely nothing with the controls thinking "shouldn't I be doingsomething"? felt weird as she just took care of herself until the roundout.Haven't tried best climb yet, need to get the gps fixed. I know I got500fpm on the gps a few times, but have to experiment more.LIKES:Like the whole plane, she is delightful to fly.REALLY like the elevator servo trim system, VERY handy.Like the control placements for carb heat and mixture, on the left, underthe control panel. Easy to reach but hard to see.Like the starter.Large wheels make taxiing over rough stuff pretty easy.Small tailwheel, makes the tail lighter.Nice having a powerful engine, I mainly cruise around now at 2000-2200 soshe's sipping fuel like a smaller engine, but it's sure nice to have thatpower on climbout or just for fun.Smoking is fun!!!!!DISLIKES:Really would tilt back the pilots bulkhead a few degrees. Thank GOD I'msmallish.Have to figure something out for the fuel indicating system. My fuelindicator doesn't start reading until about five gallons which makes itkind of hard to keep track of things. I'm considering a small drop downtube type indicator in the back drain bung where I have my water drain.This could let me have accurate readings for probably the last six or sevengallons. We'll see.Small tailwheel. is lighter, but I'm sure I'll have to replace it regularlybecause it spins so fast. I have a bag of ten from McMaster Carr, takesthree minutes to change. Have to keep those plexi windscreens clean or I can't see anything forwardwhen landing into a setting sun. Note to self!Need to add longer "down pipes" to my long exhaust to direct the smoke frommy smoke system away from the fuse and tail more. That stuff is yucky toclean.GPS is at Garmin now and I'll get some accurate numbers as soon as possible.So keep building, try to touch it every day, try to hit Brodhead as often aspossible for ideas and motivation and then. keep building, DO NOT STOP andone day you will be looking at a finished aircraft, ready to fly. Ipromise!!THE ONLY TRICK IS TO NOT QUIT!!Who's flying up to Brodhead next year who I could hook up with? Should be agaggle heading north and I want to tag along.Douwe________________________________________________________________________________Subject: Re: Pietenpol-List: RE-PIET flying characteristics
Posted: Fri Oct 26, 2012 8:55 am
Original Posted By: Dan Yocum
I plan to go. Let's link up somewhere and arrive in style. Should have HJack and Matt with me. (and Will, of course)Gene RamboOn Oct 26, 2012, at 9:23 AM, "Douwe Blumberg" wrote:> Okay good people> > Have flown RE-PIET now for five hours and thought I=99d make an early pilot report.> > My darn GPS wouldn=99t turn on the first non-wind day I had, which was the day I had planned to get some accurate speedsgotta love electronics. I have a wind vane airspeed indicator which isn=99t super accurate so I need something extra.> > She SEEMS to cruise at 70 at 2300.> My favorite cruise condition is 2000, indicating around 60. Nice and quiet and she=99ll still climb, though slowly.> Power off stalls are nice and gentle. Have no idea of the speed, the wind vane indicator reads zero.> Power on stall is more like a mushing descent, it=99s hard to get a real break. She just hangs there like a Fokker D-7 with her nose in the air.> She turns on a dime!> > After reading all the landing advice and watching hundres of landings over the last decade, I was prepared for a rather pronounced sink rate once I cut the engine. So the first few landings, I cut it closer than with the cub just to be prepared for the steep descent and each time found myself floating across the runway longer than the cub! This is on 75 degree days on grass. She seems to float more than the cub I was flying, strange I can=99t explain it because she=99s heavy, but maybe the wing axle fairing is helping a bit? Or the large airfoil wing tank? Who knows.> > So far she lands easier than the Cub, as it=99s really easy to decide when to stop her flying and because of that, you actually have more control of when things happen. She lands very easily. Yesterday was a no wind day and I was set up on final, coming right down at my aiming point and doing absolutely nothing with the controls thinking =9Cshouldn=99t I be doing something=9D? felt weird as she just took care of herself until the roundout.> > Haven=99t tried best climb yet, need to get the gps fixed. I know I got 500fpm on the gps a few times, but have to experiment more.> > LIKES:> > Like the whole plane, she is delightful to fly.> REALLY like the elevator servo trim system, VERY handy.> Like the control placements for carb heat and mixture, on the left, under the control panel. Easy to reach but hard to see.> Like the starter> Large wheels make taxiing over rough stuff pretty easy.> Small tailwheel, makes the tail lighter.> Nice having a powerful engine, I mainly cruise around now at 2000-2200 so she=99s sipping fuel like a smaller engine, but it=99s sure nice to have that power on climbout or just for fun.> Smoking is fun!!!!!> > DISLIKES:> > Really would tilt back the pilots bulkhead a few degrees. Thank GOD I=99m smallish> Have to figure something out for the fuel indicating system. My fuel indicator doesn=99t start reading until about five gallons which makes it kind of hard to keep track of things. I=99m considering a small drop down tube type indicator in the back drain bung where I have my water drain. This could let me have accurate readings for probably the last six or seven gallons. We=99ll see.> Small tailwheel is lighter, but I=99m sure I=99ll have to replace it regularly because it spins so fast. I have a bag of ten from McMaster Carr, takes three minutes to change. > Have to keep those plexi windscreens clean or I can=99t see anything forward when landing into a setting sun. Note to self!> Need to add longer =9Cdown pipes=9D to my long exhaust to direct the smoke from my smoke system away from the fuse and tail more. That stuff is yucky to clean.> > GPS is at Garmin now and I=99ll get some accurate numbers as soon as possible.> > So keep building, try to touch it every day, try to hit Brodhead as often as possible for ideas and motivation and then keep building, DO NOT STOP and one day you will be looking at a finished aircraft, ready to fly. I promise!!> > THE ONLY TRICK IS TO NOT QUIT!!> > Who=99s flying up to Brodhead next year who I could hook up with? Should be a gaggle heading north and I want to tag along.> > Douwe> > > > > > > > ============================================================================================================================================> ________________________________________________________________________________Date: Fri, 26 Oct 2012 09:18:59 -0500
Re: Pietenpol-List: Build Logs
Posted: Fri Oct 26, 2012 9:19 am
Pietenpol-List: Re: RE-PIET flying characteristics
Posted: Fri Oct 26, 2012 10:16 am
Speaking of flying characteristics, I flew my GN-1 yesterday after annual and new9/16" offset of vertical stab. I think is does help a little bit w/the offset.I should have gone for atleast an inch. I put a trim tab back on, but it'sbetter than no offset. I tossed in the new 406 ELT so that I can travel morethan 25 miles from home drome... $588 from Aircraft Spruce..not too shabby..Larryhttp://www.youtube.com/watch?v=ksmpLpkGsic&feature=plcpRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Fri Oct 26, 2012 10:41 am
Original Posted By: Jack
Subject: Pietenpol-List: ELT?Hmmmm....I never did install an ELT. My inspector never said anything about itand I never spentthe money on it. $588 for an ELT from Aircraft Spruce? Wow am I out of touch. ________________________________________________________________________________Subject: Re: Pietenpol-List: RE-PIET flying characteristics
Pietenpol-List: Re: ELT?
Posted: Fri Oct 26, 2012 11:37 am
Douwe great report thanks! Do you have any pictures of your trim install. I plan to do it. What size servo did you use?Thanks!Sent from my iPadJack TextorOn Oct 26, 2012, at 8:23 AM, "Douwe Blumberg" wrote:> Okay good people> > Have flown RE-PIET now for five hours and thought I=99d make an early pilot report.> > My darn GPS wouldn=99t turn on the first non-wind day I had, which was the day I had planned to get some accurate speedsgotta love electronics. I have a wind vane airspeed indicator which isn=99t super accurate so I need something extra.> > She SEEMS to cruise at 70 at 2300.> My favorite cruise condition is 2000, indicating around 60. Nice and quiet and she=99ll still climb, though slowly.> Power off stalls are nice and gentle. Have no idea of the speed, the wind vane indicator reads zero.> Power on stall is more like a mushing descent, it=99s hard to get a real break. She just hangs there like a Fokker D-7 with her nose in the air.> She turns on a dime!> > After reading all the landing advice and watching hundres of landings over the last decade, I was prepared for a rather pronounced sink rate once I cut the engine. So the first few landings, I cut it closer than with the cub just to be prepared for the steep descent and each time found myself floating across the runway longer than the cub! This is on 75 degree days on grass. She seems to float more than the cub I was flying, strange I can=99t explain it because she=99s heavy, but maybe the wing axle fairing is helping a bit? Or the large airfoil wing tank? Who knows.> > So far she lands easier than the Cub, as it=99s really easy to decide when to stop her flying and because of that, you actually have more control of when things happen. She lands very easily. Yesterday was a no wind day and I was set up on final, coming right down at my aiming point and doing absolutely nothing with the controls thinking =9Cshouldn=99t I be doing something=9D? felt weird as she just took care of herself until the roundout.> > Haven=99t tried best climb yet, need to get the gps fixed. I know I got 500fpm on the gps a few times, but have to experiment more.> > LIKES:> > Like the whole plane, she is delightful to fly.> REALLY like the elevator servo trim system, VERY handy.> Like the control placements for carb heat and mixture, on the left, under the control panel. Easy to reach but hard to see.> Like the starter> Large wheels make taxiing over rough stuff pretty easy.> Small tailwheel, makes the tail lighter.> Nice having a powerful engine, I mainly cruise around now at 2000-2200 so she=99s sipping fuel like a smaller engine, but it=99s sure nice to have that power on climbout or just for fun.> Smoking is fun!!!!!> > DISLIKES:> > Really would tilt back the pilots bulkhead a few degrees. Thank GOD I=99m smallish> Have to figure something out for the fuel indicating system. My fuel indicator doesn=99t start reading until about five gallons which makes it kind of hard to keep track of things. I=99m considering a small drop down tube type indicator in the back drain bung where I have my water drain. This could let me have accurate readings for probably the last six or seven gallons. We=99ll see.> Small tailwheel is lighter, but I=99m sure I=99ll have to replace it regularly because it spins so fast. I have a bag of ten from McMaster Carr, takes three minutes to change. > Have to keep those plexi windscreens clean or I can=99t see anything forward when landing into a setting sun. Note to self!> Need to add longer =9Cdown pipes=9D to my long exhaust to direct the smoke from my smoke system away from the fuse and tail more. That stuff is yucky to clean.> > GPS is at Garmin now and I=99ll get some accurate numbers as soon as possible.> > So keep building, try to touch it every day, try to hit Brodhead as often as possible for ideas and motivation and then keep building, DO NOT STOP and one day you will be looking at a finished aircraft, ready to fly. I promise!!> > THE ONLY TRICK IS TO NOT QUIT!!> > Who=99s flying up to Brodhead next year who I could hook up with? Should be a gaggle heading north and I want to tag along.> > Douwe> > > > > > > > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: Re: ELT?
Posted: Fri Oct 26, 2012 1:13 pm
yeah..My AI cleared me to fly after the annual w/in 25 miles of airport until Iget an ELT. A bit overkill, but I decided to just get the new 406-type and bedone w/it. LarryRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: ELT?
Posted: Fri Oct 26, 2012 5:13 pm
Your secret is safe with us! FYI...my FAA inspector did check to see if it was there...not sure what hewould have said if it wasn't. Gary BootheNX308MB-----Original Message-----
Re: Pietenpol-List: ELT?
Posted: Fri Oct 26, 2012 5:45 pm
Not really intending this as self promotion - more like sharing - but here is apage from the most recent Seattle Museum of Flight's membership newsletter.It features a photo of me and my Pietenpol project...Enjoy.......................--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/jake ... ___Subject: Re: Pietenpol-List: ELT?
Posted: Fri Oct 26, 2012 6:01 pm
I don't have one.....really don't want to put one in......Dan HelsperPuryear, TN-----Original Message-----
