Pietenpol-List: Re: Article in Museum of Flight Newsletter...
Posted: Fri Oct 26, 2012 6:41 am
artners, LLC]" Hmmmm....I never did install an ELT.---My inspector never said anything about it and I never spentthe money on it.---$588 for an ELT from Aircraft Spruce?---Wow am I out of touch.- -le, List Admin.________________________________________________________________________________Subject: Pietenpol-List: Re: Article in Museum of Flight Newsletter...
Pietenpol-List: ELT?
artners, LLC]" Hmmmm....I never did install an ELT. My inspector never said anything about it and I never spentthe money on it. $588 for an ELT from Aircraft Spruce? Wow am I out of touch. href="
http://www.matronics.com/Navigator?Pietenpol-List"; target=_blank href="
http://forums.matronics.com/"; target=_blank>
http://forums.matronbsp; - List Contribution Web Site -________________________________________________________________________________
artners, LLC]" Hmmmm....I never did install an ELT.---My inspector never said anything about it and I never spentthe money on it.---$588 for an ELT from Aircraft Spruce?---Wow am I out of touch.- href="
http://forums.matronbsp; - - - ---- List Contribution Web Site -" target="_blank">
http://www.matronics.com/Navigator?Piet ... __________
Pietenpol-List: 3/4 inch spar ply doublers
Posted: Fri Oct 26, 2012 6:29 pm
for those who have a 3/4 spar=2C did you go with the plans and use 1/8" ply doublers at the spar attach points or did you go to 1/4" since the original plans show the 1/8" doublers on a 1" spar - making it 1 1/4" thick rather than 1"Tom B. ________________________________________________________________________________
ReplyTo: pietenpol-list(at)matronics.comSubject: Pietenpol-List: 3/4 inch spar ply doublersfor those who have a 3/4 spar=2C did you go with the plans and use 1/8" ply= doublers at the spar attach points or did you go to 1/4" since the origina= l plans show the 1/8" doublers on a 1" spar - making it 1 1/4" thick rather= than 1"Tom B.________________________________________________________________________________Date: Fri, 26 Oct 2012 19:56:56 -0700 (PDT)
Re: Pietenpol-List: 3/4 inch spar ply doublers
Posted: Fri Oct 26, 2012 7:05 pm
I used 1/8" doublers at each rib.Gary BootheNX308MBSent on the Sprint=C2=AE Now Network from my BlackBerry=C2=AE _____
Posted: Fri Oct 26, 2012 7:31 pm
Gary=2C Assume you did that because the ribs were made with a 1" spacing but I was asking specifically about the spar attach points where the bracket is mounted. Subject: Re: Pietenpol-List: 3/4 inch spar ply doublers
RE: Pietenpol-List: 3/4 inch spar ply doublers
Posted: Fri Oct 26, 2012 7:53 pm
I used 1/8=9D on both sides of =C2=BE=9D spars on the wing side, and no spacers on the center section side.Gary BootheNX308MB
Posted: Fri Oct 26, 2012 10:49 pm
Very cool, Jake!--------Kevin "Axel" PurteeNX899KPAustin/San Marcos, TXRead this topic online here:
RE: Pietenpol-List: RE-PIET flying characteristics
Posted: Sat Oct 27, 2012 2:13 am
Douwe,I am in the process of restoring Dale McCleskey's Piet (also a RePiet!) andhave decided to slant the rear seat back as well. I sat in the Piet and Ihad forgotten how close I was to the instrument panel.If I sit back another inch or so I can actually read the instruments withoutmy glasses!!CheersPeterWonthaggi Australiahttp://repiet.cpc-world.com
Re: Pietenpol-List: ELT?
Posted: Sat Oct 27, 2012 3:05 am
Does this FAA reg actually say I have to put a 406MHZ ELT in my Piet at some point in the future? I was thinking I would just switch back and forth my existing $100 121.5 ELT that I have in the Aeronca.--Dan HelsperPuryear, TN------Original Message-----
Posted: Sat Oct 27, 2012 7:05 am
Does this FAA reg actually say I have to put a 406MHZ ELT in my Piet at some point in the future? I was thinking I would just switch back and forth my existing $100 121.5 ELT that I have in the Aeronca.Dan HelsperPuryear, TN-----Original Message-----
Posted: Sat Oct 27, 2012 7:44 am
Tom, I think you are reading your 3-piece wing plans incorrectly. My plans show the 3/32-thick centersection fittings bolted directly to the spar. The wing fittings fit outside the CS fitting. Thus the thickness of the material under the wing fitting is 3/32 inch to match the thickness of the CS fitting. OK? The fittings where the struts attach do not reallly matter, I guess. Chuck ----- Original Message -----
Tom, I think you are reading your 3-piece wing plans incorrectly. My plansshow the 3/32-thick centersection fittings bolted directly to the spar. Thewing fittings fit outside the CS fitting. Thus the thickness of thematerial under the wing fitting is 3/32 inch to match the thickness of theCS fitting. OK? The fittings where the struts attach do not realllymatter, I guess. Chuck----- Original Message -----
Posted: Sat Oct 27, 2012 8:27 am
Original Posted By: cncampbell(at)windstream.net
Chuck=2CI'm actually talking about the spot where the struts attach to the outer wing panel. There's a "u-shaped" strap that bolts to the spar over some ply doublers. The plans (not the CC plans) call for 1/8" but this was based on a 1" routed spar=2C thus making a 1 1/4" thick section at that point. If you're using a 3/4 spar and adding only the 1/8" doublers=2C you'd have a 1" section at this point. I understand the CC dimensions are different and call for 3/32" doublers.Tom B.
Pietenpol-List: Re: ELT?
Posted: Sat Oct 27, 2012 8:31 am
Hey Dan The 121.5 is legal...I got lucky and found one of those ebc 102 elt's..really smalland lightjeffLouisville kyRead this topic online here:
Re: Pietenpol-List: Re: ELT?
Posted: Sat Oct 27, 2012 8:47 am
Jack, I just used the Ray Allen servo trim components that Aircraft Sprucesells. I purchased the servo with actuating rod and the cockpit rockerswitch. Didn't bother with the position indicator. Found my own wire. Rick Holland turned me on to this system. He did a very nice inset trim tabon his elevator. I just inlet 1' of extruded piano hinge into the trailingedge as I was wanting to get finished. The whole system has got to belighter than any other mechanical system I've seen installed, but it doesneed electric.To answer the prop question. I had Jay Anderson at Cloud Cars make up a76X??? (can't remember what we decided on) because I am a strong advocate ofswinging the largest prop possible on draggy airframes. The most it'llallow the engine to spin up is about 2450 straight and level. That mightcreep up to 2500 once the engine breaks in, but honestly I quite happycruising around at 2000- 2200. The other day I tried taking off with2300rpm and it worked fine.Douwe________________________________________________________________________________Subject: Re: Pietenpol-List: Re: ELT?
Posted: Sat Oct 27, 2012 8:54 am
Original Posted By: bender
For how long?-----Original Message-----
Posted: Sat Oct 27, 2012 8:57 am
Posted: Sat Oct 27, 2012 8:58 am
Sorry, Tom, I now see that you are looking for strut attach points, not"spar attach points."The attached picture again shows 1/8" doublers under the fittings, makingthe I.D. of the fitting 1".Gary BootheNX308MB
Pietenpol-List: Re: 3/4 inch spar ply doublers
Posted: Mon Oct 29, 2012 11:41 am
Thanks Chuck and Gene. The TPI appears to be 12, quite course. I will source thepart number.Sent from my iPadJack TextorOn Oct 29, 2012, at 10:10 AM, Gene Rambo wrote:> > I have a J3 cap with a float that I may sell, but I'm almost sure it is a capwith two tangs on it, not threaded, but I can look tomorrow. > > Gene Rambo> > On Oct 28, 2012, at 5:45 PM, "Jack T. Textor" wrote:> >> All this my nose tank, a J3 tank. Any ideas what cap will fit?>> Thanks>> Jack>> >> >> >> >> >> Sent from my iPad>> Jack Textor> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: 3/4 inch spar ply doublers
Posted: Mon Oct 29, 2012 1:43 pm
Im not sure this is a correct statement, The plans (not the CC plans) call for1/8" but this was based on a 1" routed spar thus making a 1 1/4" thick sectionat that point. Yes, the spar drawings show the 1/8th inch plywood and typical construction practicewould run it under the fitting. The problem as I see it is other drawingsshow the inside width of the wing strut fitting to be 1-inch and drawings forthe upper strut fitting showing it to be 1-inch wide as well making me believethe 1-inch width . Therefore, I believe the intent was to bolt the strut fittingdirectly to the 1-inch spar with no plywood under it. I think the plywoodgoes on the side of the fitting to help keep it from rotating. Notice theodd angle the strut fitting pulls on the spar (this was later changed to the moreinline fitting used by most people). This angle will put a rotational loadon the fitting and I think Mr. Pietenpol was trying to prevent that rotationand cracking the spar at the bolt holes. Alternatively, the fitting drawingsare wrong and they should be made 1 1/4 to fit over the plywood.In my case I used 1/8-inch plates on both sides of the 3/4-inch spars. In retrospectI wish I would have made the ends different on the doublers to graduallychange the spar thickness. Now I will have to add inspection plates to lookfor cracking at the ends of the plywood doublers like many certified wood wingaircraft. Bummer.--------ChrisSacramento, CAWestCoastPiet.comRead this topic online here:
I used 1/8" doublers at each rib.Gary Boothe________________________________________________________________________________
Tom=2C I think you are reading your 3-piece wing plans incorrectly. My plans show the 3/32-thick centersection fittings bolted directly to the spar. The wing fittings fit outside the CS fitting. Thus the thickness of the material under the wing fitting is 3/32inch to match the thickness of the CS fitting. OK? The fittings where the struts attach do not reallly matter=2C I guess. Chuck ----- Original Message -----
