Pietenpol-List: Aerovee Engine Revisited
Posted: Fri Nov 30, 2012 8:26 am
Original Posted By: "Harvey Plummer"
Hey Jeff,Probably more like 75 miles, but I'll meet you wherever you like. I'mreally wanting to ck out Lee Bottom, and my friend owns Crawdaddy privateairstrip in Carrollton, both really nice grass fields.Douwe________________________________________________________________________________Subject: Pietenpol-List: Aerovee Engine Revisited
Posted: Fri Nov 30, 2012 8:53 am
Thanks to all of the input from many of you guys and some additional study, I'vecome to the conclusion there are better alternatives to the VW/Aerovee for aPiet.Simply. The Aerovee puts out about 125 ft./lbs. of torque and turns a 54" propeasily. The Continental A-65 puts out about 150 ft./lbs. of torque and the Corvairabout 160 ft./lbs. Both would do a better job of swining a 72" plus propand get the necessary thrust required for the Piet.Does anyone have a torque/HP curve for the Model A Ford?Any suggestions on the best sources to purchase Model A, A-65 or Corvair?Thanks for the input.--------Harv, 485PBRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 30 Nov 2012 09:04:18 -0800
RE: Pietenpol-List: Aerovee Engine Revisited
Posted: Fri Nov 30, 2012 11:45 am
As for the Corvair, the only/best way to start is to visit these two sites:www.flycorvair.net; www.flycorvair.com. I am glad to see that you have movedon from the VW. Continental, Corvair, Ford are ALL better choices!Gary BootheNX308MB-----Original Message-----
Re: Pietenpol-List: Tach sensor for Corvair
Posted: Fri Nov 30, 2012 1:40 pm
Does anyone know the part # and brand of the tooth counter for a StewartWarner tach for a Corvair engine. Not the big plastic one, but the small oneabout the diameter of a pencil?ThanksBarry DavisNX973BP________________________________________________________________________________Date: Fri, 30 Nov 2012 14:33:25 -0600Subject: Re: Pietenpol-List: Tach sensor for Corvair
Posted: Fri Nov 30, 2012 2:45 pm
Original Posted By: Barry Davis
Barry, WW should surely know. He uses a tooth counter all the time. Chuck ----- Original Message -----
Re: Pietenpol-List: Aerovee Engine Revisited
Posted: Fri Nov 30, 2012 4:11 pm
Original Posted By: macz(at)peak.org
Gracias Santiago...--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 30 Nov 2012 16:47:04 -0800 (PST)Subject: Re: Pietenpol-List: Aerovee Engine Revisited
